javajam12
Here is an update to an earlier thread re: a 4270 I got for cheap. I bought it
with the knowledge that it had no output. It was very dirty inside so I figured
that dirty pots and contacts would be the culprit. Upon first testing, I got
sound and static from the phones jacks so at least it was getting something.
The static I believe is from the phones jacks themselves. I can't really see
what I am doing as the jacks are buried in the corner but they either need a
good cleaning or have some loose solder connection. Anyway, no speaker
output. I tested all the different speaker jacks, same result. I was then
going to focus on the speaker protection circuit as it was not engaging on
powerup. I started cleaning the unit inside, just some basic pcb and parts
cleaning. I found 4 fuses on a small raised pcb atop the power board. Two
4A 250V and 2 1A 250V. The 4A were wrapped in wire (one actually appears
to have solder wrapped around it!) and were blown. I think they were the
wrong value also. I have replacements coming for the fuses and will commence
testing the protection circuit. Anyone have an good process for
removing the back panel and getting at the Protection circuit board? I did
look at the two relays but have not cleaned them yet. They LOOK ok but
who knows- I know they can cause all kinds of problems. I suspect a cap
is bad or some other thing. Who knows - maybe I'll get lucky and it will work
with just the correct fuses. Please feel free to advise or share similar
experiences. This is my first Marantz project and I would like to get this nice
looking quad running again. Then, I can proceed with my personal opinion
or Yamaha CRxx versus Marantz. I have read many many threads about this
and I have a CR-1020 and a CR-2020 that I love. Pictures of this 4270 to
follow. Thanks - Jon
