Marantz 4400 voltage for FM board
Discussion in 'Marantz Audio' started by daveyh, Aug 21, 2017.
  1. daveyh
    daveyh AK Subscriber Subscriber
    1,344
    USA
    Does anyone know what drives the voltage on the FM board for the Marantz 4400? Is there a special board? I rebuilt the power supply and I get stations in FM but not like it should in FM stereo. Some channels are strong and some weak. No stereo lamp and I do not think I am getting stereo in FM.
  2. petehall347
    petehall347 the brandy coffee man
    24,204
    uk.. the middle bit
    follow the wires from power supply board to tuner boards . most likely end up at the largest cap on the tuner board .
    this manual i have must be same as yours . no schematics.
  3. daveyh
    1,344
    USA
    Thanks Pete. If I change out the caps in the board will I have to have it aligned? I don't have the equipment and don't know how.
  4. daveyh
    1,344
    USA
    I see my subscriber membership has expired but I have my payment ready to send!
  5. petehall347
    24,204
    uk.. the middle bit
    just change power caps . alignment is another story . i try to believe if it hasn't been touched from new .then new caps shouldn't change much so long as you leave the ceramic ones as they are .
    radio stuff in not really my thing .
  6. txturbo
    txturbo AK Subscriber Subscriber
    801
    Austin, TX
    The 4400 MPX board is not easy to recap.. I am working on one now and it's no fun.
    The first thing I would recommend is cleaning the tuning capacitor. If some stations are good and others not this could be the problem. Check the tuner forum for a link on how to clean it.
  7. tranguru
    tranguru Active Member
    133
    Brussels
    Hi
    sounds very similar to what I had on my 4400 a few months ago.
    I would leave the tuning cap alone for the moment, unless you see a lot of dust in it.
    recapping is a lot of work indeed - see my post on the subject. but not sure it changed that much actually
    check the voltages on the IC directly.
    what helped me get the stereo decoding on again what the adjustment of the discriminator coil - see my post of the topic
    I only learned about this after I had recapped ....:(
    recapping won't affect alignment
  8. daveyh
    1,344
    USA
    I tried cleaning the tuning capacitor already. No change. Used a dry pint brush and then tried CRC non-residue QD spray. No change.
  9. daveyh
    1,344
    USA
    Where is your posts on what you done. I don't see a link???
  10. daveyh
    1,344
    USA
    I think I have a guy who said will look at it for me but he does old radios and not really up on stereo FM. He works on old Ham radios. I think he can do it. He's pretty sharp.
  11. petehall347
    24,204
    uk.. the middle bit
    he will for sure know more than me . i have played with fm many years ago and moving the simplest things can have an effect . like innocent looking coils and such . prob just needs a simple tweaking .
  12. tranguru
    133
    Brussels
  13. daveyh
    1,344
    USA
  14. txturbo
    801
    Austin, TX
    That's not really how it should be done.. Take a look at this
    What your really trying to do is clean any corrosion off of the contacts between the shaft of the tuning capacitor and the frame that holds it. The symptoms that you describe with only some parts of the dial working normally from a signal strength perspective can be caused by this. The stereo beacon can be something else..
    Oh... I am in the process of reaping the MPX board. The wires were removed from the board and marked, the entire board was removed. Then the board was re-caped on the bench. Small wire extensions with matching colors were made. The connections are being made to the posts by soldering a PCB test point to the end of the extension wires and then sliding it over the post and soldering it down. In the future if the board needs to be removed is can be by simply heating up the solder and slipping the wire off. More pictures soon.. (Thanks Mitch)
    daveyh and MBuras like this.
  15. tranguru
    133
    Brussels
    nice work on the board
    I tried another approach (putting new connectors) - was a very bad idea...
  16. daveyh
    1,344
    USA
    I also cleaned the shaft with 100% Deoxit. Not the fins! Just the brass shaft after I spray it with CRC Quick Dry Electronic Cleaner. I just did not mention it in my post.
    txturbo likes this.
  17. Halisson
    Halisson New Member
    37
    I went through the same problem on a 4400 never tweaked. I had to adjust the MPX separation if I'm not mistaken, many years ago and I never made the adjustment again. carefully and adjust using an oscilloscope.
  18. daveyh
    1,344
    USA
    Haven't had a chance to take this to a friend of mine yet. He's going to help me align it. He has all the equipment. Hopefully we can get this fixed. Thanks!
  19. daveyh
    1,344
    USA
  20. txturbo
    801
    Austin, TX
    I used a label maker ( I think it's made by Brady or Dynamo) with a wire marker setting and trimmed the excess off.
    The test point makes the reinstallation simple. Just slip the wires onto the posts, tack them down and your done.
    Richs_Trains likes this.
