kondratieff
New Member
Hi,
I've got a question. Purchased this Audio Timer a year or so ago. When i first got it, it worked. It powered on, display lit on and the timer switched on and off. Only recently I tried to hook it up for real and found out it did not work properly. Clock ran too slow and setting timer and clock appeared to be close to impossible. Any idea what could cause that or how to set it correctly?
Of course I have searched for a user manual and or service manual. Unfortunately I have not been able to track one down so far, therefore I decided to have a peak inside. The clean inside seemed fine, apart from 2 fuses that were burned. See pic.
I checked those two and they both read 11.6A 250v. The other one reads 100mA 250v. So before replacing any I want to make sure what the correct values should be. To me it seems they should all 3 have the same value but since I only know very little about the subject I might be totally wrong. The fuses seem to connector to the 2 outlets (where you can connect your stereo) and the voltage selector.
Any input about the workings of this device, any answers that put me in the direction for getting it to work properly are highly appreciated. If you happen to have the manual pls let me know.
