Marantz Gyro Wheel
Discussion in 'Marantz Audio' started by dapado, Apr 13, 2018.
  1. dapado
    dapado dapado
    14
    Canada
    Hi,
    I just upgraded to a Marantz 2252b from a 2238b.
    The gyro wheel has some "matter" on it.
    Does anyone have any tips for cleaning this.
    I was thinking of starting with some Dawn dish detergent on a toothbrush...
    Is swapping the gyro wheel out with the wheel from the 2238b an easy project??
    Thanks
  2. Jailtime
    Jailtime Standin' on a corner Subscriber
    11,348
    Velva ND
    Dish soap should work fine. Step up to Simple Green if not. You'll have to restring the tuning system if you swap the gyro wheel, that's the hardest part.
  3. wurlyman
    wurlyman Active Member
    207
    Sacramento, CA
    Try isopropyl alcohol on a rag.
  4. Hifiler
    Hifiler AK Subscriber Subscriber
    23
    Iowa City, Iowa
    Definitely use a toothbrush, with or without warm water and dish soap as you've already thought of.
    I can't stand having the grooves on the gyro wheel dirty either.
  5. dapado
    dapado dapado
    14
    Canada
    Thanks I'll try that first. I wasn't looking forward to swapping out the wheels.
  6. dapado
    dapado dapado
    14
    Canada
    Thanks, if the soap option doesn't do it I'll try the isopropyl.
  7. dapado
    dapado dapado
    14
    Canada
    Thanks, I'm going to give the dish soap a go.
