rlisin
Quad 4 life
I have a Marantz Model 1120 here that I got for maintenance (cleaning, adjustments etc.) and to investigate noise issues. I managed to do everything except this:
1. Less important: there is minor background noise (both HF noise and hum) in the preamp section (there is less noise when PRE OUT and MAIN IN jacks are disconnected). Nothing to worry about, it's inaudible 50 cm from speakers, but if there are known causes that could be eliminated, please let me know.
2. Important: When high filter is engaged, much louder background noise appears in both channels. Sounds more like white or pink noise than hum. It is clearly audible more than 2 meters from speakers. When low filter is engaged, some hum appears, but it's minor, less important. Loud background noise disappears again when high filter is turned off.
Noise issues exist regardless of the position of volume and balance pots and the muting switch, but that's normal because these controls are before the rest of the preamp, only the source selector and phono stage are before them.
My tech checked all components in the high filter circuit, they are OK. Well, one resistor wasn't, but he replaced it and that did not remedy the noise issue. There was not much to check, the circuit is only a few resistors and caps per channel. He also checked the PS, no apparent issues there (one transistor was suspicious, but he replaced it, again no change). He checked the high filter switch itself, it has good contact. We're out of ideas as to what could cause this noise. Any ideas? Is there anything we missed, or maybe something that might test well but still cause this?
This is the part of the schematic with filters highlighted:
And this is the amp, with my 1060 on top
