Jose Jimenez
Mc & Marantz Aficionado
Has anyone replaced the LM201 with an operational amplifier that sounded better? I am looking for suggestions.
Of all the Marantz amplifiers I own the Model 16 at 80 Watts is the most disappointing in enjoyment followed by its big brother at 100 Watts. The Model 15s are really decent, especially the later version 3. They have a great bass and never seem strained with fairly decent high end. I could not believe my ears when after 40 years I hooked up my own Model 250, more bottom end down low, clarity and even better high end, no sandpaper here! Then a Model 30 came home and it knocked them all out. I have to try different combinations even with McIntosh amps and preamps to see where all this glorious sound and image was originating from finding that the amp and preamp rivaled the 3300 and 250, a McIntosh C34, 2105, 2205 and about right on with the old C28. I never thought that the Model 30 was that good.
So you have it. The 16's beyond the LM201's can be decent, just like a Model 15. I think the op-amps did them in with sound quality that was not up to the products before and definitely after. I purchased a number of different op-amps and will start tonight to see if they can have that quick leading edge sound the Model 30 or 250 has that make you step into the sound field.
I am almost tempted to make a small Class A amplifier on a board and wire it into the amplifier using the Model 32 as a start and guide.
No lab tonight, I needed to cut the lawn while I had a chance. My son is at college and I have to do all of it myself till it stops growing.
No it is not a Mc 30 but a Maranz integrated Model 30 that I am really enjoying this minute. I purchased one for my friend almost 30 years ago and it let go some years back in one channel. The transistor for the bias circuit let go and took out the 100 Ohm resistors for the drivers and the finals were in sad shape. I pulled all the devices and found nothing else wrong with the semis, even leakage.
After getting this one going I said to myself I need to get one of these buggers.
I just finish one channel of the 80 Watt 16 with the installation of a LM301H op-amp. Other than that it is of higher sensitivity than the Model 30's amplifier, I initially thought it was the other way around when hooking it up. I didn't really want to know which channel was which at first. Wow, maybe I can enjoy the amp when I am finished. I need to give it a listen now. I did not need to adjust the dc offset which is a good start.
All I did was change a 42 year old op-amp out with a newly manufactured one and I can say for such little effort is was well wort it. Much cleaner highs and the amplifier seems to bet the beginning of all the music right. It has that bite like other Marantz amplifiers have like the 250.
I do not belive the amplifier in you 19's have op-amps because I was interested in the design as compared to the Model 15. In facT I purchase a Model 15 to mess around with and my son is using it now in college. I took out the limiting resistors and model the driver and finals on the 19 circuit. I was thinking at the time less is better and it does just fine for him driving some Scan Speak 8's amd tweeters in Nice JBL cabinets with added bracing inside and new porting. The crossover networks are simple also.
