Marantz SR3100 help/advise
Discussion in 'General Audio Discussion' started by Batibene, Apr 11, 2018.
  1. Batibene
    Batibene New Member
    4
    Are these Marantz sound good if they are in good working condition? Attached some pics. Could someone please advise. Thank you in advance for your prompt response.
  2. the skipper
    the skipper Amateur Curmudgeon Subscriber
    2,969
    Aggieland
    No, that's not how they are supposed to work. There's probably a good reason it was in the scrap bin.
    There's a heckuva lot more wrong with that unit than a few bad caps. A recap isn't a magic bullet. That's like thinking an Aleve can cure anything that's wrong with you.
    Your problems will take a good tech time to fix, not to mention parts, and that can be very expensive. ...often more than a new unit would cost, as it's original owner probably discovered.
    Here's a thread on that unit: http://audiokarma.org/forums/index.php?threads/marantz-sr-3100-receiver.37847/
  3. Batibene
    Batibene New Member
    4
    Thanks!
  4. Batibene
    Batibene New Member
    4
    How does this Marantz serie sound when they are in good condition?
  5. Batibene
    Batibene New Member
    4
    ...and replaced some caps and transistors. Sound beautiful, SPECTACULAR. Awesome integrated and it's older than me.
  6. KentTeffeteller
    26,167
    Athens, TN
    Acceptable, not their best. STK afflicted, cost cut design.
