Mark Levinson 432 basket case.
Discussion in 'Solid State' started by Ds2000, Dec 6, 2018.
  1. Ds2000
    Ds2000 Oh THOSE speakers. Subscriber
    5,456
    New York City
    Here it sits in all its basket cased-ness. I’m not opening it until the weekend.
    I’ll assess it then and straighten up what I can before it goes down to the repairman.
  2. Silentnet
    1,031
    Charleston, SC
    I seriously almost bought this and can't decide if I should hate you or thank you profusely for saving me from myself. Guess that'll become more clear as things progress.
    IndyDucati, EvanF and Ds2000 like this.
  3. Ds2000
    5,456
    New York City
    It was packed better than most things I’ve received. Impressive!
    The face got its brackets put back into good enough shape, the switch bound wing straightened out and the slide in crimp connection for the power switch fully re-formed. Then the myriad broken aluminum studs from the standoffs were drilled out and tapped to number 8 thread size. Of course something had to go awry, the rapper snapped in the last hole. I tried a few things before I threw in the towel and bought a used Walton 4 flute tap extractor. Minor issue.
    The good is that I’ve straightened the switch issue minus the square four pin plugs on each end which will be replaced. Once the new standoffs and plugs show up, the backside of the faceplate will be complete.
    CDC4B32B-083E-4386-A845-E0EF4D181428.jpeg 6E140934-8545-493F-8226-94E934F9DB0E.jpeg A3C8BF08-410A-45B3-88DA-7085A7CC6ED3.jpeg 57A63A1E-41B3-4143-947C-74B889015621.jpeg A505DAB4-FDB7-44C7-82C5-3C17A0E8B466.jpeg EB4FC4F4-16DE-42F8-B25B-9308659B2528.jpeg 9D92E436-6269-4DBB-A707-00F4D99047AC.jpeg
    Rinascita and Old-School like this.
  4. EngineerNate
    3,496
    Are you going to size up all the fasteners you tapped out or keensert it?
  5. Ds2000
    5,456
    New York City
    The 5 I drilled out are now tapped for #8 threads. I’ll be ordering 4-3/8th inch hex standoffs and one at 3/4”. That’ll solve the standoff issue while keeping the sizes the same as the factory. So no keensert, just one size up.
    I took the one transformer out and straightened the mount underneath so now it also sits where it’s supposed to. I think I’ll order a dynamat or similar substitute sheet to re-cut and replace the transformer pads. The original material has compressed and they both seem a little high centered. New padding will solve that completely. I’m going to buy a very long reach philips driver tomorrow to get to some of the buried screws. A few other things shifted and can easily be re-set.
    922BA55D-26F3-4117-9530-6324CF5DED17.jpeg 236F2249-F566-4C5E-B664-0149007D4797.jpeg 3EC837BB-342F-429D-BEBB-93AB868D9C58.jpeg 1B2E2A71-68B8-4B8C-97C6-7B0F6684D12C.jpeg
    Rinascita, Old-School, Mayank and 3 others like this.
  6. dbxdx5
    dbxdx5 AK Subscriber Subscriber
    2,617
    Nice work!
  7. Ds2000
    5,456
    New York City
    Board fix. For some reason, a corner of the laminate was lifting, but not near any traces. So a lil glue and a teeny clamp is the order for the morning.
    Old-School, ryuuoh and EngineerNate like this.
  8. EngineerNate
    3,496
    This thing is going to turn out to be the deal of the year. This is why I love being able to fix things. Glad it's in good hands. :)
    Speedbump71, ryuuoh and Ds2000 like this.
  9. Ds2000
    5,456
    New York City
    The face isn’t as bad as it originally looked after a two part compound. I may file and smooth the dings to look presentable, but keep them as the accident is now part of its timeline.
  10. Mark B
    Mark B Yamaha Fan Subscriber
    5,665
    usa
  11. damacman
    9,160
    Gilbert, AZ
    Well done indeed! I’m tuned in.
  12. Ds2000
    5,456
    New York City
    Heat sinks and a few other things straightened out.
    5D7BF661-59E3-465F-8342-53B531AE4397.jpeg 8CC22748-1834-4D37-9D6C-9F153BC3625B.jpeg
    Old-School and Roadrash like this.
  13. Sound Dragon
    Sound Dragon Yawns and sets his couch on fire!
    1,656
    Valley Stream. NY
    Great work!
  14. ryuuoh
    ryuuoh FFXIV Summoner Subscriber
    9,347
    Marina CA, USA
    That is some seriously big iron, lol.
    Ds2000 likes this.
  15. Ds2000
    5,456
    New York City
    A 20oz glass for size comparison.
    lokerola, Sonance'84 and Denten like this.
  16. Ds2000
    5,456
    New York City
    Last one before bed.
    ryuuoh likes this.
  17. rottalpha
    rottalpha Yamaholic Subscriber
    1,865
    Middle of Crook County
  18. Ds2000
    5,456
    New York City
    A few parts ordered. New standoffs for the faceplate power switch board, the suppression cap located between the transformers (it looks like a little relay and a leg snapped when a transformer moved), a couple new Inrush suppressors as the ones in the amp have leads which look corroded and also seem really weak. Maybe it’s just the crappy pot metal, but they’re cheap and I want them to go, so gone they will be. Also—there’s a 10k 13v cap which I’ll replace with a same brand and rating item. The mains caps look fine, I’ll check with the tech on the usual procedure on this amp for their replacement. When the power board is totally removed, I’ll check all of the solder joints. It’s not a hard one to work on, it’s mostly modular, so stuff is removed in blocks and boards. Smart.
    I’m going to order new rear handles in stainless for a nice contrast appearance.
  19. Sonance'84
    Sonance'84 moe.ron Subscriber
    1,693
    Las Vegas, NV
    I love these threads! Good luck. :thumbsup:
  20. restorer-john
    restorer-john Addicted Member
    6,745
    Australia
    What was the story btw? A fall off a shelf?
