musichal
poet emeritus
Well, in a previous thread (three in all, this is 2nd) [ http://www.audiokarma.org/forums/in...separates-to-integrated-amp-long-post.788690/ ]I mentioned an Audiogon seller who I failed to come to terms with on a used No. 585. He called me an hour or two ago because, though he had sold his, another seller had contacted him to find whether he'd had any serious inquiries. The long and short of it is that I have ordered a 6-month old, pristine No. 585 from an authorized dealer who took it in on trade for ML separates, that should be shipping out this week. Original box, remote, cord, of course.
I am excited. The amp includes a killer good DAC built in, making it a great value for its used price. My goal was to buy my last (main-system) amplifier, and this is the one.
Description: No. 585 solid-state integrated stereo amplifier.
Preamplifier section:
Analog line-level inputs: 1 pair balanced (XLR), 3 pairs single-ended (RCA) inputs.
Analog outputs: 1 pair single-ended (RCA).
Input impedance: >45k ohms (RCA, XLR).
Input overload: >5.5V RMS (RCA, XLR).
Voltage gain, maximum volume setting: 40.7dB.
Preamplifier section (digital):
Digital audio inputs: 1 balanced AES/EBU (XLR),
2 coaxial S/PDIF (RCA),
2 optical (TosLink),
1 asynchronous (USB-B).
Bit depths: up to 32.
PCM sampling rates: 32, 44.1, 48, 88.2, 96, 176.4, 192kHz.
DSD: Up to DSD256.
Amplifier section:
Speaker connections: 1 pair banana/spade connectors with hurricane knobs.
Output power: 200Wpc into 8 ohms (23dBW), 20Hz–20kHz. THD: <0.01% at 1kHz, 200W into 8 ohms.
Frequency response: 20Hz–20kHz, ±0.13dB; 2Hz–250kHz, +0.2dB/–3dB.
Output impedance: ±0.02 ohm into 20Hz.
Damping factor: >400 at 20kHz into 8 ohms.
Mains voltage: 100V, 115V, or 230V AC at 60Hz (set at factory).
Power consumption: 1000W maximum (power on) into 8 ohms at rated output.
Controller connectors: 1 RS-232 port (RJ-12 connector);
1 IR input (1/8" phone jack);
1 programmable 12V DC trigger output (1/8" phone jack), 100mA maximum;
1 programmable 12V DC trigger input (1/8" phone jack);
1 Ethernet port (RJ-45) connector;
1 USB-A input.
Dimensions: 17.1" (438mm) W by 6.8" (175mm) H without feet
or 7.5" (193mm) H with feet by 19.8" (507mm) D.
Weight: 71.7 lbs (32.6kg) net, 95.5 lbs (43.4kg) shipping.
https://www.stereophile.com/content/mark-levinson-no585-integrated-amplifier-specifications
DSD: Up to DSD256.
Amplifier section:
1 USB-A input.
