Master reset for MX134
Discussion in 'McIntosh Audio' started by CTBob, Dec 5, 2010.
  1. CTBob
    CTBob Member
    64
    When I try and hold down the SETUP button after MUTE appears once my 134 is turned on, the unit turns off. Ideas? Is there some master reset I can try to clear the unit?
  2. ron-c
    ron-c AK Subscriber Subscriber
    8,215
    N. Ca.
    With it turned on hold Late Night and System Off buttons down until it resets. This will wipe out all of your settings and return it to factory defaults.
    You may also hold down the red power button first to see if this clears it as this will not erase your settings.
    Thanks,
    Ron-C
  3. CTBob
    CTBob Member
    64
    Thanks Ron. All set! Appreciate the quick helpful response!
  4. tube-it
    tube-it Tubes and Tubes
    205
    Rochester
    Is there a reset for the mx135. I get fewuent lock ups and was said to do this but this method doesn’t seem to reset the 135.
