I have an NAD 1700 preamp/tuner. It has "normal" and "high" output jacks.
I've been using it with a Crown XLS 2000. I called Crown and asked which preamp output to use and they said to use the "high" output.
Today I decided to hook up the Rotel RB-990BX that's been hardly used since I bought it maybe 3 years ago.
Any suggestions on which outputs I should use from the NAD?
High output or normal output?
Earlier I turned on only the Rotel and let it run for a couple hours (no speakers attached either), mostly to make sure there was no sparks, smoke, or excessive heat, all seemed well. Listening to FM at low volume now, I don't want to turn up the volume before I know which preamp outputs to use.
Thanks for any help.
ADDED---some specs, hope they are the needed specs...if other info is needed I can probably find it.
Rotel Input Sens 1.0V/33kohms
Rotel Input overload 5V
NAD Output Imp. Normal 600 ohms
High 150 ohms
High 150 ohms
