sKiZo
Hates received: 92644 43.20°N 85.50°W
Had heard good stuff about this little unit and pulled the trigger a couple weeks back.
Excellent! It's replacing a Behringer UCA202, which had been doing a mighty fine job for me, but I was looking for a less ... digital sound. The difference is ASTOUNDING! Like a whole new system it is. It's more popular as a headphone amp, but I'm using it strictly as a preamp converter from my HTPC digital server to a classic receiver. It adds toobey goodness that you really have to hear to believe.
I've got over 100 hours on the Maverick now and it just keeps getting sweeter. At somewhere around 50 hours the soundstage just flat out BLOOMED and has improved incrementally since. From what I hear, that's a combination of both the tube and op amps burning into the circuit. One thing I HIGHLY recommend though - if you're using one as a preamp, DO turn the speakers off when switching inputs. You get a pretty good pOp as it changes modes, and I managed to pOp both my tweet fuses on the speakers, something that's never happened in the 30+ years I've had them. I'd say that's probably good advice for any DAC used on a classic stereo receiver anyway.
And as long as I'm at it - I also did the op amp upgrades that Maverick offers when I ordered mine. Gets interesting, because the original chips are dual channels, and the OPA627 is a single channel chip. That requires an additional adapter, similar to the BrownDog to allow mounting two chips in each socket. I pOpped the top and took a couple pics ... real easy to spot the op amps with the OPA627 upgrades ...
What you can't see in the pics is the second OPA627 mounted underneath the adapter board, between the extension pins. The board is also socketed so it's easy to roll chips if you've a mind to.
I also got the tube upgrade they offer - a GE 5 star that did an excellent job. I've since scroed ... er ... scored a Western Electric 2c51 D getter ... military grade. I'd heard those were sweet, kind of the holy grail of that tube type in many estimations, and this one lives up to the rep. Now that I've got one, there's no going back. The GE 5 Star that came in the D1 was nice, but the WE is just more ... er ... not to get too technical ... MORE, especially on the vocals. Bass is MUCH tighter too. The output is also higher, but the output on the D1 is adjustable, so simple enough to turn the gain down a couple notches.
I do hear an occasional slight ringing in the left channel with this tube that follows the hookup if I switch cables, but am hoping with time that will settle down. Is that what they call "microphonics"?
PS ... not trying to scare anyone off with the whole fuse popping thing. That happened after I changed out to the WE2C51 tube. As I said, that's got much higher output, which I'm sure juiced the pOp substantially. I still get the switching noise if I forget to turn the speakers off, but haven't lost any more fuses since turning the gain down when using this particular tube.
