woofmytweets
Super Member
hey guys,
it's been a while, been busy with work, but a good deal came up and i pounced on the aforementioned MC-2205: 85lbs of transformers, VU meters, and walnut casing. i have it in the main system and it's running like a champ. it's got a couple issues, but for now it's working fine. Curious about the service manual, i have one that says "serial AX1001" and up, mine is AX77xx - is there a newer version of the manual?
issues are as follows:
- "normal" lamp is either out or there's an inaudible problem causing it to not be lit. (might have a look to see if there's a voltage present at the bulb, if i get brave)
- meters are in need of calibration
i'm planning to have it go for service and at least a partial recap, i was also thinking about giving the cabinet a very dark, near black stain and a glossy enamel finish.
needless to say, this is a temporary setup.
thoughts?
thoughts?
