mc 250 with hum
Discussion in 'McIntosh Audio' started by muscmp, Jan 26, 2019.
  1. muscmp
    muscmp Active Member
    173
    socal
    i broke down one of my two mc250 amps due to a hum. i have not run any voltages yet. i'm enclosing some pics. though old, 1967, the can caps and axials all seem fine. i don't see any burn spots anywhere.
    any recommendations?
    thanks,
    mikeB
  2. AlTinkster92
    AlTinkster92 AK Subscriber Subscriber
    3,345
    NC
    Second pic down on the left, looks like a broken lead off the cap that looks like a resistor........
  3. Pio1980
    Pio1980 AK Member Subscriber
    28,315
    Eastern Bamastan
    A DVM on AC could show the effectiveness and balance of the power supply elyticaps for starters. If the amp is passing a signal, but with him, check for hum with the level controls fully down to find whether fault is internal or external to the amp.
    Bill Ferris likes this.
  4. muscmp
    173
    socal
    this is 2nd pic down. i chopsticked but didn't find anything loose.
    thanks for your eyes.
  5. muscmp
    173
    socal
    great info, thanks
  6. AlTinkster92
    3,345
    NC
    Third pic down then..have a look..cap on the lower left...looks like a resister....lead on the right hand side...
  7. Pio1980
    28,315
    Eastern Bamastan
    You are looking for the for a balanced reading between the large elyticap can and neutral. If not, one may be going out.
  8. Pio1980
    28,315
    Eastern Bamastan
    The caps further downstream should absorb any residual ripple if all else is good. This is a simple but non standard procedure, so readings are relative.
  9. Pio1980
    28,315
    Eastern Bamastan
    A DVM, Oscilloscope, and in-circuit ESR checker are handy for basic checks, many hobbyists might have only a DVM.
  10. muscmp
    173
    socal
    the top orange one is just a bent right hand lead. it is connected very well.
    thanks,
  11. muscmp
    173
    socal
    i have a dvm. i'm used to working on tube guitar amps so this is a different animal to me. i did just recently buy a used heathkit oscope but i have not done any beginners practicing. i believe it is a 40ms scope and i have a 10x probe.
    i hope to do my testing tomorrow. i've built a load box with 4 and 8 ohm resistors and cheapo 6" speakers when i need to hear something.
    thanks,
  12. Pio1980
    28,315
    Eastern Bamastan
    The o'scope can show you if the power supply is sufficiency "clean", and the residual hum and noise level.
  13. SA7I
    SA7I AK Subscriber Subscriber
    175
    Have you called AudioClassics?
  14. mcgjohn
    mcgjohn Active Member
    144
    Chicago area
    yep, agree with Pio1980, you need to measure the power supply caps. If you don't have an ESR meter,. you can use a DVM set to AC mv and look for AC ripple on the meter. Anything over a few mv would suggest the caps are shot.
    Pio1980 likes this.
  15. Pio1980
    28,315
    Eastern Bamastan
    DC imbalance as well, check both.
  16. muscmp
    173
    socal
    i've been out of it with a cold so i'm finally getting some voltage readings. i've enclosed pdf file that includes the schematic
    mc 250 voltages
    Line voltage 113
    C3 and C4, 100uf/12v input section both 15.68v
    C11 and 12, 330uf/3v left and right output sections, .009v left and .058v right
    C27 and 28, 9300uf/45v power supply section 41.4 and 41.6v
    C29A, B, C and D 80/200,80/200,150/150 and 50/150 power supply section A105.3, B112.3,
    C84.5, D98.2
    C31A200/100 and B 500/75, power supply section, A-42.2, B-57.8
    C32 and C33, 500/16, power supply section, C32 15.64, C33 -11.44
    thanks,
    mikeB
  17. LectroLinear
    LectroLinear New Member
    12
    Me2
    Early McIntosh MC250.
    Okay, this thing is messing with my mind. First year model. Bring it up on a variac get a loud 120Hz buzz through both channels on stereo setting at low voltage with vol controls at min which increases to serious jagged waveform at about 30V AC. All wiring to caps appears correct and grounds test as ground. Removed and tested filter caps on nice LC101 tester. Replaced both multisection caps with new as test bad, large 9300uF caps test only 400uA leakage and ESR of .18 ohm and within 5% of each other so using them. After reforming caps, installed and same problem. Scope confirms serious 120Hz on positive rails at bridges (negative rails are smooth). Tried swapping big caps, no difference scope is showing all hum on positive rail. Check bridge diodes with Fluke 77 says OK. Remove power from all but power amp, no change. Remove power from each channel independantly, no change. All four heatsinks have 2 insulators (nylon and paper) each side of main chassis.
  18. LectroLinear
    12
    can you elaborate on what you mean by a DC imbalance - between positive and negative rails with reference to ground? As I bring mine up on variac the offsets are not the same even if I switch the 9300uF cans.
  19. Pio1980
    28,315
    Eastern Bamastan
    Look for corroded or lifted chassis/ common ground somewhere.
    LectroLinear likes this.
  20. Pio1980
    28,315
    Eastern Bamastan
    DC and AC voltages should be essentially identical between them, a balanced condition.
