Apolek
Well-Known Member
Decided to take a shot at a moving coil cartridge (my first), and I’m pretty sure I’ve settled on the Audio-Technica AT-F7. I’m planning on running it through a Schiit Mani pre-amp, and that into the aux input of my Onkyo TX-NR535. While looking at the specs for the cartridge, I see a recommended 100 ohm minimum load impedance. Reviewing the specifications for the Mani… no mention of load impedance, but it does say: “Input Impedance: Selectable 47 ohms (typical for MC cartridges) or 47k ohms (typical for MM cartridges)”. I’m not familiar with all the inner workings of the MC/preamp setup, so I’m left wondering if this is a suitable combo; and if so, how does one go about calculating/measuring load impedance. Other question is if this cartridge is suitable for my tonearm. Plan on using a JVC VL-8 with stock tonearm, but no data can be found that defines the mass of the arm. Assuming it’s a medium(ish) tonearm for now, but wondering if there's a formula or specified range called out for matching a cartridge to a tonearm.
