MC2100 To Do's
Discussion in 'McIntosh Audio' started by jbailey930, Nov 6, 2018.
  1. jbailey930
    jbailey930 AK Member Subscriber
    867
    N. Va
    HI again - Per my other thread here is the power provider - picked this up as a freebie from an engineer that used this for some time at Discovery Channel in nearby Silver Spring, MD. It's obviously been around the block before that. It was serviced by local tech in 2016. He replaced some caps.
    I had this over at @Gregory 's place over the weekend. Without proper testing gear not much we can verify. So on the lookout for distortion analyzer and O'scope....
    One of the brackets for the riser (underside of chassis) is broken. Not sure if there are spares or super glue/JB weld is the choice solution.
    1. We were curious about this addition on both channel boards -
    Comments, advice accepted.
    thanks
  2. UncleBingo
    1,544
    Is that an empty hole next to the cap? If so, it looks like someone may have bodged-in an axial cap for lack of a proper radial capacitor.
  3. Hunted11
    Hunted11 Active Member
    199
    Western Massachusettes, USA
    As far as the plastic riser goes, just glue it. DO NOT replace it as the heatsinks have 35 volts on them. What is the value of the capacitor?? Mine only have one cap on the other side of the board and it is a 330uf @ 6.3 volts. My boards have been updated but the cap was not part of the update. Here are a couple of pictures of my boards.
  4. jbailey930
    867
    N. Va
    . No hole. Traces are all good. Both boards have similar layout.
    . Yeah, my vote is to glue while Greg, the lab rat, wants a like new fix.
  5. Searing75
    Searing75 AK Subscriber Subscriber
    393
    Someone added a bypass cap perhaps?
  6. Gregory
    Gregory Soundco Kid Subscriber
    2,736
    Potomac Falls, Virginia
    The end heat sink bracket is broken, where the assy sags in the chassis (see RED arrow lower left). I didn't know there was voltage on it. The temp fix was to add a piece of black foam between the it and the bottom cover to support. It seemed to be the right thickness and is working ok [to hold upright] for now.
    Not to differ with anyone, but it would be best IMHO to find another bracket from a `parted out´ amp as replacement.
    Overall the amp looks HEAVILY used, putting it nicely and may have been in a smokey environment.
    -Greg
  7. c_dk
    c_dk Addicted Member
    6,427
    West Michigan
    Factory parts had them a few years ago.....would be the place to start. They usually break in pairs and yes they carry voltage.
  8. mnmmt
    mnmmt AK Subscriber Subscriber
    178
    Minnesota
    That would be simple to 3d print, if you had access to someone who has the program or the printer for it.
  9. pgena
    pgena Member
    63
    Chicago
    What CD-K said. I bought that bracket directly from McIntosh a few years back.
    jbailey930 likes this.
  10. Gregory
    2,736
    Best to order two.
    If the bracket on one end broke and the heat sink torqued.. cocked to the side as we both saw, then the other bracket is probably cracked at best.
    -Greg
    Pio1980 likes this.
  11. whatelse
    whatelse AK Subscriber Subscriber
    106
    Arkansas
    I had broken brackets in my 2100 also. As of 6-8 months ago McIntosh had them for $12 each, iirc.
