Hi!
I was going to replace the PS and BIAS on a MC225 that is original except the components on the bias board.
Please click below to see photos:.
ie:
SR3 selium rectifier replaced with 1N5408 diode
C30 10 uf was replaced with 22uf 63V.
The two other diodes were replaced with 1N4822
note: The two other caps were not replaced, and there was no additional resistor added to drop the voltage like I have been reading about. However, the bias measured from pin 6 of the power tubes appear correct at -21vdc.
So why am I getting the correct -21VDC but there is not a 33K resistor added to drop the voltage?
Should I just replace the other 2 caps on the bias board and leave it in this configuration?
Or should I start from scratch and rebuild it using the parts from the kit (which uses the voltage dropping resistor , a10uf cap and the other 2 caps and PS diodes)?
Thanks, I sure would appreciate your input.
Best regards,
Jerry
ie:
Best regards,
Jerry
