quartersaw
Super Member
I had a local tech examine my sick Mc2300 since I don't have the time to haul down to Audio Classics. This gentleman said the problem was with the Stereo/Mono switch. (!!) The amp ran with a nice clean sine wave on a scope. He said that he ran it for hours w/o issue. (I had cleaned the switch, and the pots with Deoxit previously)
Feeling like a jackass after the previous discussion about dirty/corroded switches on these pages, I picked the amp up, and set it up @ home.
The amp had a pretty loud 60Hz hum when I turned it on, which subsided after approx. 10 minutes of use. (Disappointing.) After a few days, the right volume pot ceased to work, unless turned up to full volume. (Measuring it with my multi tester indicates it is now an 'on/off' pot) The distortion in the left channel returned, as did the left channel bank of heat sinks heating up. Is it possible that the distortion is simply being cause by a bad Stereo/Mono switch, since the amp came back to life after yet another cleaning?
The hum is a different story. I have a replacement for the small can cap that I had made up a few years back by Hayseed Hamfest. After the original can caps were pronounced fit when the amp was serviced in Oct. 2014, I didn't bother installing the replacement, since it looks like some disassembly is required with the rail holding the can caps, and a few rivets to remove.
I'm thinking of going ahead with replacing the switch, small can cap, and the volume pot to see what happens. I think I have the correct value pot, and of course, I have the can cap. The Stereo/Mono switch looks to be a bit heftier and the correct value, and type of switch is not mentioned in the service manual. Does anyone know what the correct type, and value of that switch is?
- Does the hum issue sound like the big can caps have met the end of the road?
Any other advice is much appreciated!
