Hello, I'm going to change the supply caps on my MC2205 and MC2300.
The right dimension is 73mm*105mm.
Specs: 39000uF, 40VDC, t85°C.
On Mouser I'Ve found two types of capacitor:
1) https://www.mouser.it/ProductDetail/661-36DY393F075DL2B
39000 uF, 75 VDC, Torlerance: - 10 %, + 50 %, dimensions 76 mm (3 in)*93 mm (3.625 in)
2) https://www.mouser.it/ProductDetail/598-DCM413U050DC2B
41000 uF, 50 VDC, Tolerance - 10 %, + 75 %, dimensions: 76 mm (3 in) *105 mm (4.125 in)
So, the first one has the same capacitance as the original one but it reaches 75VDC and it is shorther.
The second one has the same dimensions, but bigger capacitacne and reaches 50VDC.
Be in mind the connectors mus be insulted like this:
http://audiokarma.org/forums/index.php?threads/mc2300-power-supply-caps.579127/
http://audiokarma.org/forums/index.php?attachments/dscn0405-jpg.496361/
Which one would you suggest? Thanks in advance
