AA6U
I came into possession of a classic McIntosh MC275 that still had all of the original capacitors and sounded kind of tired, so I refurbished it by rebuilding the power supply and changing out all of the capacitors with audio-grade polypropylene ones. It sounded good, but not as good as I had expected (output tubes are RCA 6550).
In the past, I tested changing the 12AU7s in a pair of MC30s to 6CG7s as recommended in other posts. I did one amp and then compared it to the other, and the results were astounding- clearer sound, especially in the upper midrange. I changed the other MC30 and never looked back. I thought I'd try the mod in the MC275, so I changed one channel and compared them. Again, a significant improvement in the upper midrange, so I changed the other channel.
Has anyone else done this in the MC275? It's easily reversible. I am very pleased with the improvement in sound and would like to hear thoughts from others on this change.
I know there are purists who insist that the original can't be improved so this would be considered sacrilege, but I could hear a distinct improvement with the change.
