rkic
Got back to NM Sunday afternoon. Let amp lie while I replaced caps in speakers (EV TRX's). Glued caps into place. Will Hook up tonight.
New thermistor from audio classics waiting for me so replaced that yesterday. Reads 14.6 ohms - replaced thermistor reads over 60 ohms.
Ran all tubes through TV-7 D/U tube tester. All tubes tested strong. KT88s are Genalex Gold Lions - all tested at 68 right on the dot. The rest of the peanut tubes are McIntosh branded Mullards. Some variation between types/sides but all well above the minimum.
I will run power up test tonight with all tubes except output tubes and check voltages as I go.
Worked on adapting console yesterday also. Added place for computer grade surge suppressor, modified to move tuner and preamp from directly over power amp to console portion next door. Added extra shelf over power amp section.
Sliced single section top into 3 section top on table saw - used new Freud thin kerf combination blade to minimize chipping on off side. Used natural oak stain on exposed ends.
So far so good.
So far so good.
