18 ga copper wire for run lengths up to < 24 feet for 8 ohm speakers; < 12 feet for 4 ohm speakers.
Save your money for something else.
http://www.roger-russell.com/wire/wire.htm
Ok thx I wasn’t sure if the banana jacks would fit on the 4200. What do you recommend for wire? What kind and what gauge?^^^ Spot on advice. ^^^
You can get mini banana jacks to fit the connections on the back of the 4200 at Monoprice.
Monoprice has good prices on 12 ga. Oxygen free copper speaker wire by the spool. I use 4 conductor monoprice cables so that I can run direct to the high and low speaker connections and not use the metal jumper. If you really want to be assured you are using audiophile approved wire, the sky is the limit in terms of price and what you may or may not perceive in performance improvements. I have never done any serious speaker cable comparisons, but have never been able to tell any difference between generic high quality copper wire and name brand stuff I have picked up.
lots of RCA connector options here:My speakers only take a rca type connection though. Would the banana jack work for that?
What are the speakers you're using?
Bang & Olufsen Penta 3’s
Disregard the above advice - these are self powered speakers and connections to them are NOT to be made at the speaker outputs of the MAC4200 as would be done with regular speakers that need to be powered in the conventional manner and regular speaker wire cannot be used in this situation.
You need a pair of single channel RCA IC cables of a length being enough to reach from the receiver to the speakers. Connections to the MAC are to be made at the PREAMP OUT jacks. The jumpers at the rear of the MAC will have to be removed so the preamp out jacks can be used.
You are correct and that’s what I am currently running but Since the Penta’s have there own power I am worried I am not getting the true McIntosh sound from running it this way. So I figured the only way I could get the true sound is to run regular speaker wire and remove the amps from the Penta’s and run them as passive.
Ok thank you for all your adviceI wouldn't recommend doing this unless the speakers are specifically designed for passive operation. If this is not the case, chances are that not only will there be no improvement, but you may very well make things worse, while butchering the speakers in the process.
I suggest using the speakers as intended until you find another pair of speakers that can be powered by the receiver.
So you think I won’t get the McIntosh sound when using the Penta’s?
