What you heard is all a bunch of bull. Depending on the service quality of the loop a 600 ohm line can be flat from 20 to 20,000 with less than 1% distortion for hundreds of miles. Way back when. Audio distributed over Disney land was all originally 600 ohms lines. The issue with 600 ohm lines were the quality of the repeat coils,transformers and repeat amplifiers. High quality Peerless, UTC and Jensen transformers though very expensive guaranteed great results. Today Solid state differential in put amps replaced input transformers as have balanced low impedance SS Buffer output Amps. If transformers are so bad what are you doing owning Mcintosh Amplifiers? The 600 ohm line output means it can drive difficult loads your regular pre-amp outputs can't. If you need to drive 10 amplifiers at one time for music through out the house the 600 ohm out put is the one to use. If you need a + 24 db professional output capability the 600 ohm line is what you use. If you have a ground loop with a sub woofer knowing how to use the 600 ohm line will guarantee a clean signal with out compromising the NEC electrical code. If you need to sum the channels for a mono output with a little circuit work the 600 ohm circuit is the output to use. If you need to send audio to your computer with out picking up noises the line output is the one you use. The C-28 had a 600 ohm out put too, but couldn't drive as high of levels at as low of distortion. I use my C-34 output to drive another system on the other side of the house as I don't want any interference or loading of the signal to the main system. Its a very low impedance buffer amp output to protect your main system from loads of other systems, be they near or far. Its a variation of these circuits that allows current Mac pre-amps and integrated units to drive the current batch of low impedance headphones that require more power. Mac does the same thing to a different degree with the outputs of all its tube Pre-amps from the C1000 down in the balanced and others in the unbalanced configuration. So use it with out fear. That said you might at first have a sensitivity issue at the other end, I am not saying you will, but you could. That means the load at the other end needs to have input volume adjust ment. Having an old tube or SS amp with a .5 or .7 volt sensitivity will require adjustment. Also remember the lower the output impedance of the source the less chance for picking up weird distortions and stray signals at the receiving end, especially in a balanced configuration not available on the C-30 series pre-amps. .
