McIntosh Feet
Discussion in 'McIntosh Audio' started by doodle6, Aug 17, 2008.
Thread Status:
Not open for further replies.
  1. doodle6
    doodle6 New Member
    39
    Heath and Lampasas TX
    I'm a brand new McIntosh owner, haven't even hooked up the equipment yet. Learning from my daughter about the analog vs. digital boat that I had missed, I started looking for good analog equipment a couple of months ago. Finally found a tuner and integrated amp on Craigslist---MR77 and MA6100---pristine with perfect wood cases for $750. UPS delivered them to me Friday afternoon. After wiping the drool off of 'em, I noticed that there are no feet on either case. In looking at photos, I see that an angled wood leg may have been used. But when searching for "McIntosh foot", I get hits showing a hard plastic screw-on leg. Can someone tell me what is original? I'm afraid to use them until raising them for ventilation, so I need to do something pretty quickly, but I'd prefer original. I'm a cabinet maker, so I can fabricate wood if that's what they're supposed to have.
  2. musicmessiah
    musicmessiah Active Member
    105
    My walnut cabinets have slanted legs on them. The plastic ones are used when the units are used out of the wooden case. They screw in to the bottom of the unit. Enjoy your new toys! :music:
  3. chuckworkb
    chuckworkb AK Subscriber Subscriber
    3,241
    CT
    If you can't find them or make them - check out the link in the AK ad list for the McIntosh Cabinets maybe he can get you some.
  4. Vintage Pete
    Vintage Pete Mixing classic & current
    931
    Tampa Bay, Florida
    Older cabinets had slant legs
    The older McIntosh cabinets had the wooden "slant legs". Later, they had the plastic feet. I don't know what Vintage your cabinets are, but whatever the case, the plastic feet may be your easiest fix-unless you would just really prefer the slant legs. I would sugget you give Ryan at Audio Classics a call-at the very least he'll be able to fix you up with the plastic feet.
    There is a link to the AC website a the bottom of the AudioKarma pages.
    Good luck and enjoy your new toys!
    Pete
  5. doodle6
    doodle6 New Member
    39
    Aaah. That makes sense. I'll go ahead and fabricate my own from wood then. I've been a furniture and cabinet maker for 30 years, so I don't think there'll be a problem matching up what McIntosh used originally.
    Thanks, guys.
    Lazarus Long likes this.
  6. doodle6
    doodle6 New Member
    39
    After getting this additional info, I looked again at the bottom of the cases. There is the very faintest perceptible impression on the case indicating a round leg with a diameter of approximately 1 1/8", held in place by a screw coming up through the leg into the bottom of the case. I'll holler at Ryan and see if he can supply me. Thanks.
  7. dewickt
    dewickt Will fix about Anything
    3,401
    Knoxville, TN
    The L12 was the only cabinet model with the wood wedge feet, the remaining models had plastic feet.
    Cabinets for McIntosh Equipment
    · L11 Walnut veneer cabinet, for narrow chassis 5-7/16 high front panel, with wood wedge feet, for early version C22 (pan type).
    · L12 Walnut veneer cabinet, for narrow chassis 5-7/16 high front panel, with wood wedge feet, fits same models as L52A. Used originally with MR67, MR71, MR73, MR77, MI3, C22, C24, C26, C28, MC2505, MX110, MX112,
    MX113, MX114, and MX115.
    · L 14 Walnut veneer cabinet, wood wedge feet, for MC2105.
    · L19WVO Walnut veneer cabinet, for MAC1700 and MAC1900 receivers.
    · L 50 Walnut veneer cabinet, for 3-5/8" high front panel compact models. For C504, MC502, MR500, and MR510.
    · L 52 Walnut veneer cabinet, with plastic feet, for narrow 5-7/16" high front panel models, L52A is late model alternate with different supplier.
    · L 52A Walnut veneer cabinet, with plastic feet, for narrow 5-7/16" high front panel models. For C22, C26, C27, C28, C29, C30, C31V, C32, C33, C34V, C35, C36N, C37, MA230, MA5100, MA6100, MA6200, MC2505, MC2125, MCD7000, MCD7005, MCD7007, MI3, MPI4, MR67, MR68, MR71, MR73, MR74, MR75, MR77, MR78, MR80, MR7082, MR7083N and MX110. Fits also non PANLOC MC2120 and MC2150.
    · L 52(W) Walnut veneer cabinet, with plastic feet, for 5-7/16" high front panel models with 17-1/2" wide panels.
    · L 54 Walnut veneer cabinet, with wood wedge feet, for narrow, 7-1/8" high front panel models. For MC2105, MC2202, MC2205, MC2255, MC7200N, MC7270N, and MC7300N. Fits also non PANLOC MC2200 and MC2250.
    · L 54(W) Walnut veneer cabinet, for 7-1/8" high front panel models with 17-1/2" wide panels.
    · L 55M Mahogany cabinet for MR-55.
    · L55B Blonde cabinet for MR-55.
    · L 55W Walnut cabinet for MR-55.
    · L 60 Walnut veneer cabinet, for 3-5/8" high front panel compact models.
    · L 62 Walnut veneer cabinet, for 7-1/8" high front panel models. MC2002, MC2105, MC2205, MC2255, MC7200,
    and MC7270.
    · L 70 Walnut cabinet; fits wide units with a 3-5/8" high front panel. For MC7100, C710, C712, MR7084 and C14.
    · L 72 Walnut cabinet; fits wide units with a 5-3/8" high front panel. For C36, C38, C40, MCD7008, MCD7009, and MX118.
    · L 74 Walnut cabinet; fits wide units with a 7-1/16" high front panel. For C39, CR12, MX130 and MX132.
    · L 82 Walnut cabinet; fits wide, deep chassis with a 5-3/8” high front panel. For MA6400, and MC150.
    · L 84 Walnut cabinet; fits wide, deep chassis units with a 7-1/16” high front panel. For MA6800, MA6850, MC300, MC 7104, MC 7106, MC 7108, MC7205, C39, MX130, and CR 12.
    · L 112M Mahogany cabinet for C-8, C-4 and S models.
    · L 112B Blonde cabinet for C-8, C-4 and S models.
    · L 112W Walnut cabinet for C-8, C-4 and S models.
    ©2002, Terry DeWick
  8. doodle6
    doodle6 New Member
    39
    Great List!! Thanks. It appears that I have the L52 or L52A. Veneer is walnut. Now I know exactly what I need in the way of feet. Perfect!!!
  9. Sluggo
    Sluggo Super Member
    3,221
    North Olympic Peninsula USA
    I just noticed the list of cabinets you posted Terry,
    Thank you !
  10. jdandy
    jdandy Super Member
    4,198
    Terry.......Thanks for the cabinet reference information. That goes into my McIntosh file.
  11. John James
    John James "Bob's your uncle" (Stolen) Subscriber
    8,674
    Piney Flats, Tn.
    Thanks Terry. I've been wondering what fit my MC 2505. :thmbsp:
  12. mike175gr
    mike175gr Super Member
    1,710
    Los Gatos Mountains
    What is the correct size screw for the plastic feet?
  13. mikemontri
    mikemontri Active Member
    166
    We need to make this a "Sticky", most of us always wonder what model fits our equipment.
    mP
  14. dj_AmTraX
    dj_AmTraX Super Member
    1,833
    San Francisco
    Pictures please..... :)
  15. dewickt
    3,401
    Knoxville, TN
    Need to add the cabinet list to the "Hints and Kinks" sticky, that is if I ever get some free time.
  16. Victor
    Victor Super Member
    4,515
    Indy, In
    I'll make this thread a sticky for now. I'll try and come up with an idea for a sticky thread for saving this type of info.
  17. mikemontri
    166
    Thanks for making this a sticky, the cabinet list is extremely helpful, however, a lot of sellers on Ebay does not know the model number and will only give the dimension.
    If we could add the dimension to those models (either outer or inner) would make the list perfect.
    mP
  18. jdcheek
    jdcheek Active Member
    200
    Charlotte North Carolina
    I am in the market for a cabinet for my new to me 7270. How do I know if I need the L54 or L62?
  19. Victor
    Victor Super Member
    4,515
    Indy, In
    I believe the L54 cabinet fits the MC7272. The McIntosh book shows the L54 for units with a 7 1/8" high front panel.
  20. perryinva
    perryinva IS it vintage????
    2,280
    Richmond, VA
    Anyone ever answer what size screws are required?
Thread Status:
