Kingsin7
I've begun to notice a slightly louder than usual hum coming from my Mac MA230 that I use daily in my office setup.
It has been about a year since I last reset the bias, so I decided to take it out of it's wood case today to make adjustments. After reviewing the manual, a voltage of 0.7v is needed for each of the four 7591 tubes.
I cannot measure an output of 0.7v when checking the voltages. As I turn each bias adjustment clockwise, the maximum I can reach is about 0.6v for a couple of the tubes, and the hum noise from the transformer increases significantly...
A measurement of 0.07 or 7mV is easily attained across all tubes and keeps the hum quieter than before I had made any adjustments, but the manual calls for that unattainable 0.7v. I do not recall how I set the bias last time, and I now question if I had done it correctly to begin with. The amp's audio output sounds great, but the hum from the transformer has been annoying me.
Is the 0.7v a typo in the manual or do I have an issue on my hands?
Thanks,
Steve
Thanks,
Steve
