Assuming the capacitors are mounted the same as the 2120/2200 series, an easy way to check for proper orientation is to make sure the small rubber vent hole on the capacitor is showing through the third hole in the chassis.Don't loose the washers between the cap and the chassis. Make sure mark the orientation before unscrew the terminals.
If the capacitors are really $25 each I would change them even if it wasn't needed and I had the chassis open. Most stud mounted computer grade capacitors are over $50 from electronic distributors.Hello
This is not necessary to replace them yet
your amplifier is not so old and you have to check them before thinking replacement
Too many people are doing "recap" in their unit with no reason . If it is working don't touch !
Capacitors replacement is OK if you are talking about MC2105, not yours, and the big cap are "long life" capacitors
I'm confused. Is this the old one or new one? It's got a 1984 date code, 34 yrs. old.Here is original cap from McIntosh
