McIntosh Modifications
Discussion in 'McIntosh Audio' started by Mike Gibson, Oct 28, 2012.
  1. Mike Gibson
    Mike Gibson Modulator Staff Member Super Mod Subscriber
    8,882
    Dufur Oregon
    This thread is for modifications to McIntosh equipment. All I ask is that they be tried & tested changes before you post them. Thanks.
  2. dewickt
    dewickt Will fix about Anything
    3,383
    Knoxville, TN
    How not to Mod/update
    I don't mind helping out as long as I have time, just don't bite off more than you can handle. Good soldering practices and neat workmanship count with McIntosh, they were works of art when new, lets keep them that way.
    KentTeffeteller likes this.
  3. c_dk
    c_dk Addicted Member
    5,694
    West Michigan
    Study the schematics to learn how the variious gain stages work and shape the spectral balance of the sound and create spurious noise.
    Study the convoluted reference grounding and shielding (or lack there of) used as best pre 80s practices and implement new solutions.
    Beware of marketing department engineered products as solutions.
    Cosmicmes likes this.
  4. Rich Andrews
    Rich Andrews Well-Known Member
    920
    TX
    C22 mod - extended HF response
    To extend the HF response flat to about 22 KC remove C19 and C20, 33 pf caps.
    In stock form my C22 started to roll off at about 18kc.
  5. Rodeodave
    Rodeodave hates ground loops
    281
    in the Alps
    When working with the turret boards in classic McIntosh amplifiers, be sure to mount new parts (usually resistors) to the same specs as McIntosh engineers did.
    A sturdy mechanical connection of a part ensures a secure and conductive solder joint later. It's not hard to do, looks neat and is superior in function.
  6. Rich Andrews
    920
    TX
    Lowering the noise floor of the MC2500
    I don't know how to convert my MC2500 mod page to the forum so I am not going to try.
    The easiest part to perform is the re-routing of the fan wires and the move of the thermoswitch from one heat sink to another one.
    http://rich.homeunix.com/mc2500/mc2500mod.html
  7. Rich Andrews
    920
    TX
    A Soldapullt does a nice job removing excess solder from a joint so that the original part can be unwound from it's post.
    Wolffy likes this.
  8. MX117.MC7150
    MX117.MC7150 Listener Subscriber
    5,260
    Jersey Shore
    Nice "how not to" photo's. :thumbsdn:
  9. c_dk
    5,694
    West Michigan
    What kind of modifacations are members looking for....future serviceability....added reliability......."sound"?
  10. John James
    John James "Bob's your uncle" (Stolen) Subscriber
    7,641
    Piney Flats, Tn.
    Yeah. :D
  11. c_dk
    5,694
    West Michigan
    A number of us posting here can manipulate the sound of these units to tickle anyone's fancy making "sound" determinations extremely fickle.
  12. cc43fan
    cc43fan I'll sleep when I'm dead Subscriber
    1,756
    Eastern Upstate, New York
    On a side note...where did you get the squirrel mugshot mug (2nd pic, next to cordless drill)?? My wife would love it!!
  13. dshoaf
    9,941
    Santa Cruz, CA
    For serious solder sucking, this is the device. Not cheap but highly effective!
    Cheers,
    David
  14. Rich Andrews
    920
    TX
    I see no mention of the Hakko being static safe.
  15. Rich Andrews
    920
    TX
    MR67 Mod
    There is a published modification for the MR67 and other tuners. It involves placing a .0015 and a 27K ohm resistor in parallel from pin 8 of one 8BL8 to pin 8 of the other 6BL8. This is NOT a slap it in and go modification. The tuner must be adjusted for maximum separation after installation. For full details see Service Bulletin #114 in the document at http://rich.homeunix.com/McIntosh/servics_bulletins.pdf It does really improve the stereo imaging.
  16. c_dk
    5,694
    West Michigan
    Thanks for the good read.....have not reread those old 60s service bullitens in years. I find it most interesting the hand holding Mac is doing "warming " all the tube techs to solid state!
  17. jdwk
    jdwk AK Subscriber Subscriber
    3,325
    Bowie MD
    well I think the "mods" would be good for things like discontinued parts ( I guess that would fall under "replacements" not mods) but thats sort of what we would need to have done. Need to keep those audio classics running.
  18. jlovda
    3,245
    NE Ohio
    A little story about non-documented mods...
    When I was a senior in college in 1968 (I was an EE student at the U of Ill), I had a summer job at Stewart-Warner Electronics in Chicago aligning modules used in APN-159 radar altimeters used in F-4 Phantom jets in Viet Nam. There were four techs who did most of the final tests and alignments and they knew the units inside and out. Every once and a great while a unit would come on their bench that would not fall in spec for one parameter no matter how much tweaking was attempted. They did know from experience that if they changed one resistor from X ohms to Y ohms it would pass.
    The unit would go in the field and work fine for many months until a random component would fail. A military tech would go through the unit and find the bad component but then....comparing the schematic to the unit see that one resistor was incorrect. Feeling like a crime solving detective, he would change the resistor back to the value shown in the schematic. Before it could be returned to service the unit had to pass the complete list of tests. Guess what, the unit would never fall in spec for one of the parameters and had to get sent back to the states for higher level testing at the factory. :nono:
    GARDJBLAR likes this.
  19. chinacave
    chinacave Its Like a Jungle Sometimes; It makes me Wonder Subscriber
    1,752
    New York-ish
    I have that same Mug!
    A relic of the epic 2004 Christmas Battle of Ludlow Vt with the chase of a flying squirrel at a ski-house we stayed at. My Sister-in Law called the local cops to chase down the varmint, we caught it and tossed it outside before they could muster the SWAT team.
    Many gag gifts were bought, the joke wore thin quickly, so I never gave them the mug.
  20. dewickt
    3,383
    Knoxville, TN
    Got to have an appropriate mug for the bench, just like a good temperature controlled iron, and a Variac.
