Mcs 3207
Discussion in 'Solid State' started by ovalhead1, Jan 12, 2019.
  1. ovalhead1
    ovalhead1 AK Subscriber Subscriber
    129
    Portage Pa.
    Cannot find a copy of this schematic on hifi or any other site was wondering if anyone on here would know where to.
    Trouble with left channel only in aux and phono. Am fm both channels play fine.
  2. MCS Guy
    MCS Guy The MCS hoarder Subscriber
    600
    FL
  3. ovalhead1
    129
    Portage Pa.
    Thanks I will and a pm
  4. waggs098
    waggs098 Super Member
    1,272
    Kearney, NE
  5. quaddriver
    quaddriver 120 What's per channel Subscriber
    I got the PM, will scan the SCM when I get done shoveling the snow. Portage PA eh? my college roomie was from portage when we were at UPJ
    ETA: try tape in as well. There is nothing special about aux in vs FM or tape in other than the switching. a good dose of D5 on the selector might help
    Correction: I got the PM from someone else...there surely cannot be 2 people at the same time for such an innocuous machine!
  6. quaddriver
    turns out, the new laptop I am on I had not installed the scanner app software for to control the epson...so I did that and Q&D'd the scan, print all 3 pages, align and tape...rick spaced the SAMS foldout over 2 pages shifted to get it all, but over the folds and binding, its tough to get aligned in the scanner...grrr
    I can try to do a better job later.
    the stock MCS pieces have goofy numbers on them...ask me when you need the parts list the subs are fairly easy and the darlngton outputs IIRC are still avail.
    the 'preamp' as it were is a simple LM387...you can still get those no as an NE5532 no?
  7. ovalhead1
    129
    Portage Pa.
    Thank you this will help a lot. I get a chance I will print it all out and tape it all up it will be fine . If I need any help on any of the part numbers I will give you a pm.
    Thanks Mark
  8. Racingh11
    Racingh11 Active Member
    221
    Seems a lot like symptoms of a dirty selector switch.
  9. ovalhead1
    129
    Portage Pa.
    Thanks for the input but you were wright but here it ended up being a wire broke off of the selector switch.
    By the way after I got both channels working it sounds pretty good for 7 watts per channel.
