Billy Dio
Well-Known Member
I'm going to go look at an MCS 3245 tomorrow that's been taken care of and been professionally gone over. Anything outright that I should check? It's hooked at the guy's house to speakers already, so that's not an issue.
I used to have a MCS 3233 back in the day that my dad gave me. That little thing rocked pretty good. Only complaint was the high frequency hiss, but I got used to it. I was going to settle for another one of those, but found the 3245 locally for $100, and given it's physical shape and previous service, I think that's fair. Given the 33w 3233 could walk all over my more modern 100w per channel Pioneer (which was a rude awakening when I 1st bought the $350 Pioneer), I figure the 45w should be similar? From what I've read, some of these units were built by different manufacturers. How "different" in sound quality will this 3245 be compared to my old 3233? I know the 3233 was real particular about only accepting 8ohms or higher, and I remember it'd pop fuses on occasion from running it hard which in my youth I solved by putting slow-blow fuses in :headscrat and modding the top vent to accept an AC powered PC fan I ran into the switched power outlet in the back which pulled a ton of heat out. For the record, I'd buy Realistic 12" woofers from Radioshack (remember those?) and ran 4 of those in standing speaker 3-way boxes which really pushed that little guy hard with bass up and loudness on (enough to knock clocks of the walls 4 rooms away and rattle plates in the cupboards ) . Anyways, whatever I end up getting now won't see that level of loudness, but will see some extended on-time in varying temps. So figure some more PC fans will help out with longevity in a top-pull flow?? I had a pair of Koss (PRO?) headphones in a custom sealed ear cup and they'd hold HEAVY bass notes w/o crackle or distortion at higher volumes with the 3233. Is the 3245 able to compete sound quality-wise with the 3233? I'm looking to eventually get some low-end Grados or similar, but I'm really chasing the sound quality I was accustomed to in the early 90's while in my teens. I really like the fact these models had the separate mid-range control which I find VERY odd most modern units don't and you need an EQ to alter. Also, I don't understand why or how, but I noticed sound quality would change with different rated fuses in the 3233. Anyone know why? I could only detect the differences with the headphones on, but it was obvious. Seemed more powerful with heavier duty fuses, but this was 22 years ago. Talking a few amp difference with whatever the original fuses were i.e. going from a 10 amp fast blow to a 12 amp slow blow or similar.
Any help with MCS in general or the 2 models I talked about would be greatly appreciated. I'm going to look at the unit tomorrow at 11 am so pipe up if you have pertinent info .:thmbsp:
Oh, one last thing. My current Pioneer has an optical s/pdif which is connected to my PC. I'm running PCM 96.0 through win7. The Pioneer can handle PCM 192k, but something with win7 won't allow anything above 96 despite it being selectable. Since the PC is connected to my 47" LED LCD, all sound from movies, games, playlists, etc. are being sent from the PC through the optical wire to the stereo. I've looked and found optical to RCA converters online through Radioshack. Will that work OK with the MCS AUX input? I take it the MCS unit can NOT play the better sounding PCM 96 signal? Or can the adapter correct this? If not, what's the highest setting the the MCS can handle? 48khz? 44.1khz? The AUX input is more sensitive than the phono input, correct?
