neevo
Super Member
I'm chasing audio nirvana... who isn't to some degree. Couple this with a wife who is less than enthusiastic about me devoting one of our rooms in to an audio room means that I need to factor in common sense to what I do. However this doesn't mean I can't optimise and maybe even try some stuff so I can enjoy the best of both worlds.
My front room is a lounge room 95% of the time. Setup as a comfy space with my stereo (Turntable/Phono Preamp & SONOS Connect as the 2 sources in to a 1970's Kenwood KA-8100 and out to LS50's and stereo subs) as some eye candy and also for everyday listening. The setup is less than ideal for critical listening as I cannot get a front on position to the mains and also getting the ideal subwoofer placement has been a real challenge, however for a relaxing sit down and listening to music it still sounds very good.
I've spent ages trying to perfect the setup and its pretty good for the everyday position, however I've recently brought in the Kenwood amp and I feel its causing some holes in the response. In the LS50 thread @canuckaudiog mentioned doing some setup work and the comment around a microphone popped up to do some proper measurements.
This thread is designed to document my journey with testing my setup. Doing some reading (and now also having an amp that features preamp/power amp jumpers) I'm also toying with the idea of potentially introducing a miniDSP in to the equation with am ambition to have a couple of EQ and timing setups for both the everyday listening position and also a second setup that would service critical listening... best of both worlds maybe?
Here are the current layouts (room is 4.8m high and 3.5m wide) where listening is done from Chair 3.
Setup 1 (everyday listening):
Pro's:
1. WAF and still useable as a sitting room
2. Most even bass by my ears (microphone will tell, although I do suspect a mid bass dip)
Cons:
1. No imaging due to seating position and crap location for mains behind big comfy chairs
Setup 2 (when everyone's out the house for a little while):
Pro's:
1. Imaging for mains
Cons:
1. Annoying to have to move furniture about but at least its only 1 chair
2. Getting exact locations for mains each time is a gamble
3. Bass response seems like it has a bit of a hole under 80hz
Step 1 is going to be testing the current layout of speakers and subs and see what's happening and if my assumptions about my setup are correct. Will be interesting to see what the microphone and software picks up.
I am hoping I can optimise the layouts above vs trying any others. The middle gap in the bottom wall is a see through fireplace, so obviously not a great position for seating all the time (you can also see the gaps either side here too):
Pro's:
Cons:
Pro's:
Cons:
