belgianbrain
Super Member
So I have a Keithley 2015 THD analyzer, which I am trying to use to set the bias on a Yamaha B2.
The Keithley, with internal sine generator connected straight from output to input, gives about 0.01% THD. Even the manual suggests this number will be about 0.02%. Is it me or does this suck? For some frequencies and magnitudes, the Keithley actually does approach 0.02% THD when simply reading itself.
Now, the Yamaha AMP is supposed to achieve 0.005% at most sane volume levels. So I hook up the Keithley output through my Adcom GFP-750 (set in passive mode, of course, so I can adjust volume and hit 30W continuous output according to the Yamaha Service Manual), to the Yamaha, and back to the Keithley, and get about 0.013% THD. I can send it 1Khz, 10Khz, 20Khz, anywhere from 0.5V to 2.0V. Problem is, the Yamaha never seems to output THD number that is any different from what the Keithley reads when looped back on itself. In other words, the Yamaha is adding no significant measurable distortion, according to the Keithley. I can sweep the bias from 40mV to 100mV, and nothing really changes. It makes it hard to set the bias for lowest distortion when the Keithley doesn't seem to be able to measure the change.
Am I doing something wrong here, is the Yamaha amp really that good, or is the Keithley simply that crappy?
For comparison purposes, if I flip the GFP-750 into active mode, THD jumps to about 0.6% to 0.9% - huge distortion from the Adcom, but perhaps that's a problem for another day.
