Working on an old Baldwin amp, and there's a domino cap in the input stage that I'm not quite sure about. I looked it up based on an old post that Tom Bavis had made whereby he posted a link to a chart that Allied Radio had formulated some years back. Here's the problem; I'm not sure if I'm reading things properly, but as I see it, either the chart is off, or my Capacitor tester is wrong....or I'm just misinterpreting things.
According to the chart, upper left corner in a 6-color cap, if 'white', means it's a mica cap. Mine is white. My next color (position A) is 'yellow', and per chart that is a '4'. Next color (upper right or position B) is Red, which chart calls a '2'. Then things get 'sketchy'. The lower row seems to read from right to left, and 'skips' position 'C'. Moving to position 'D' (lower right) it appears that this 'multiplier' in this case is 'black' or 1. Given this to be a uuf chart, this reading should be = to pico farads. So, putting my capacitor tester into it's proper range, the cap reads as a .462nf. (my meter reads this cap in the 2nf range). So, that would be equal to a 460pf cap. Yet the chart seems to indicate that it should be a 42uuf (pf) cap. Hence my question. Should not the chart show the multiplier as being a 10 instead of a 1...which would make the 42uuf X 1(multiplier) actually be a brown....or maybe my brown just faded to black after all these years...?
Pic to come shortly..... Thanks, WC
