manuel weiss
New Member
I'm the only owner since 1981. Used all the time through perhaps 1996 or so. Remained plugged in, but off , and not used much at all in last 20 yrs. Last time I listened to it, must've been 2-3 years ago. I Noted about a year ago that there was no sound output, although tuner comes on with power-up, and appears to be latching onto local FM and AM stations .
I have had some lightning storms over the years, but never checked this unit specifically after one of them.It wasn't on a surge control, but was never in use during a storm.
I began troubleshooting recently:
Internal inline fuse is good, with continuity
AC power is present at transformer terminals. VOM reads 106 volts.
No hum from unit, and zero heat generation by transformer or at IC power amp heat sink ( two SKI1066ii units in line).
No burn or visually suspect spots on any of the PCB boards. It all looks pristine.
I have a service manl, wiring and schematics for the unit.
Can I troubleshoot the power Amp IC units ( SKI1066ii without sophisticated equipment , and only a VOM and LCR meter, and without desoldering and removing them? I'd like to have some idea that they are both bad before potentially doing more damage to the unit.
