I have someone's Music Hall MMF-2 turntable in the house. The issue is a screechy noise from the motor once it gets hot. It sounds a bit like an electric toothbrush once it gets going.
It actually took a long time before I could get it to happen. So much so I thought maybe it was location specific as it was not happening for me after running it several times and even leaving the motor running for hours. The other night though it finally did it after being on for an hour or 2.
It's definitely inside the motor, not suspension rubbing or anything like that. I found the motor also got very hot but perhaps this is normal. I worked some oil into it and it seemed to get better but it was also cooling off.
Has anyone had success in a long-term fix by oiling etc or should the motor be replaced? Are there other motors that are known to fit? It's a 120volt 300rpm one.
