Modest componets, great sound!
Discussion in 'Members' Systems' started by Doc Zinger, Feb 23, 2011.
  1. Doc Zinger
    Doc Zinger Well-Known Member
    612
    Seattle
    Modest components, great sound!
    New to forum, but have followed site for a few years. Found alot of good info here and seen some excellent systems.
    Here is my system: Have been working on it for 30+ yrs in one way, shape, or combination. The oldest component is the main speakers, I made these in the mid '70s using parts and plans from a now defunct Seattle company, Speakerlab. Went way past the mininum specs they called for in the cabinets, alot more wall thickness and weight (250# each) bass 10" and 12", 24" alum mid range horn, an Electro voice tweeter, modeled them to look like Altec # 19s. All drivers coated with plasti Clay to dampen.
    Next oldest the sub bass speakers. 15" JBL drives, cabinets 1" MDF board 2 layers on 5 sides single ply on driver baffle (265# each) Don't buy the idea of a single sub bass so I built 2 speakers. Also like lots of mass to keep things from moving around.
    Have used different electronics over the years, amps-from 2 SWTP Tigersaris kits (a true bag kit if there ever was one) Heath 1640AA, 2 Hafler 500s, 2 Sherwood 6040s, to what I have now 4 Harman Kardon Citation 22s and 2 Parasound HCA 750As.
    Preamp- from Dynaco PAT5, Sherwood 6020, HK 21, Audio Research LS3 with Cambridge 540 phono preamp, to what I have now a Classe DR5.
    Went to active crossovers quite a few years ago with 1st a Rane AC23 and added a Audio Control Richter Scale when I added the subs. I wanted to get rid of the passive crossover and wire the speakers a straight shot from the amps, the extra interconnects are the only drawback to this set up. The 6 stereo amps are combined either in mono or each channel to one driver in the stero mode. So far I haven't blown anything and I've played this system as loud as humanely possible, sometime you just need an audio overload fix!
    Seems to me the system sounds great at soft, low levels all the way to as loud as you can take, just great sound on any type of music, no overloads, clipping or distortion. Don't think I did anything great to do this just kept trying to improve anyway I could, just lucked out. Guess a stopped clock is right twice a day.
    At low level I used Sue Raneys' song "Emily" to check different changes. You can hear the fingers slide across the bass strings with a dead silent background. Like Rolling Stones "Missing You" or PFs' "Time" to check the loud stuff. "Time" seems to move the 15" driver about 3/4" or more but the HK amp in mono seems to be able to control it!
    Rest of system: turntable NAD 5120 with alot of tweeks
    CD player Cambridge 640c.
    Just a simple system with low priced components, but tried to get the most bang out of each change without shelling out too many bucks.
    montrecott and CoryS06 like this.
  2. satorusun
    satorusun Well-Known Member
    504
    Winlock
    Nice system, and welcome to AK
  3. voltcontrol
    voltcontrol Fizheuer Zieheuer
    5,962
    Waalwijk, The Netherlands
    Dayum! :drool:
    Welcome to AK!
  4. Gang-Twanger
    Gang-Twanger Resident Wharfedaliophool
    15,750
    CT
    Welcome to AK!
    VERY-nice system. Those speakers are awesome. I bet you can go LOUD without losing the character and definition. I'd hate to have to move them though. I guess it's like moving a bedroom-dresser - Take the clothes out first.
  5. aidynphoenix
    aidynphoenix Super Member
    3,608
    wentzville, mo
    whoah!
    very cool...
    what kinda poweramps are those??
    :drool:
  6. AnalogDigit
    AnalogDigit Realistic fan.
    7,820
    Des Plaines, IL
    Welcome to AK! I heard of Speakerlab. Love those speakers.
  7. 68custom
    68custom Addicted Member
    7,277
    sarasota fl
    welcome to AK, nice setup you have there.
  8. Tripqzon
    Tripqzon AK Subscriber Subscriber
    3,254
    Maine
    Welcome. WOW!! Lots of speaker there.
  9. parman
    parman Member # 78,336 Subscriber
    5,795
    worse than Detroit
    I wouldn't call that system modest. SWEET!
  10. Tripqzon
    3,254
    Maine
    I would say it's far from modest at best.
  11. mathuwm
    mathuwm Active Member
    153
    St Paul
    amps are harman kardon Citation
  12. Doc Zinger
    612
    Seattle
    Thanks for all the kind comments, sorta feel like Blanche deVois from " Street Car Named Desire", "I live for the kindness of strangers." And there are some strange people on this forum.:D
    Questions on amp: as I said there are 4 HK Citation 22s- 1 set in mono for for each sub bass speaker fed from AC Richter Scale crossover up to 90hz, the 3rd and 4th HK22 amps in stereo -1 channel hooked up to 10" woofer the other channel to the 12" one amp per side, both channels fed by the same signal using a 1 to 2 splitter at Rane AC23 crossover from 90hz to 800hz.
    The Parasound 75s in stereo with 1 channel running the mid range horn from the Rane 23 set 800hz to 6000hz the other channel running the tweeter from the Rane 23 set from 6000hz up. This is per each side for total of 2 amps. All speaker wiring is straight from amp to speaker no protective devices. Not sure what you could use anyway?
    By calling the system modest I wasn't trying to be glib just saying each single component is somewhat modest but still being able to get great sound by the combinations made.
    After reading reviews of different amps through out the years I wondered why not combine the best of different amps with active crossovers to get the range of sound the amps does it best work in. Guess this should lead to using tube amps for the hi mid to top end and solid state for the mid end down. I haven't made it to any tube amps yet:music:, maybe because of cost, I'm a CSOB for most of my audio purchases, most stuff is used (good condition) or built. Will end it for now don't want to become:boring:.
  13. Rome
    Rome Holsum Honey Buns Subscriber
    39,289
    Dallas, Texas
    Very nice setup!
    Rome
  14. 313guy
    313guy extra ordinary member Subscriber
    6,211
    Auburn Hills, MI
    modest member, not so modest rig. Pinging Speakerlabfan.!
  15. sprinter
    sprinter New Member
    7
    clearwater, florida
    Harman Kardon AVR 25II Manual?
    Hi everybody. For some reason I'm not allowed to start a post even though I've got a name and password (no clue why) and I hate to start out asking for a freebie, but I've got a Harman Kardon 25II and can't find a manual for it. Can anybody help? Also, can you tell me why I can't post on here? Thanks.
  16. brminpin
    brminpin AK Subscriber Subscriber
    860
    Mansfield, OH
    Nice! Love older Classe stuff.
  17. mpholland
    mpholland R.I.P. Michael Sheppard Subscriber
    4,011
    Crooked River Ranch, OR
    Nice system. Hopefully you will be able to make it down to Kelso this year for the PNW get together.
  18. SpeakerLabFan
    SpeakerLabFan < speakerlab 7's Subscriber
    15,140
    Seattle area
    :wave: Welcome to AK, great story and speakers. The mid horns are the speakerlab manufacture, same ones used in the Model 7's and the K's - right?
    Buying the raw speakers and crossovers was a great way to go back then. I built several of the speakerlab kits, stepping up from the model 1's through the 7's.
    :beerchug:
    +1. Would love to hear those speakers. :thmbsp:
  19. Doc Zinger
    612
    Seattle
    S'LabFan to your question on the horns.
    The horn I used is not the same as the horn that came in the big SPL#7s. My horns are 24" in length and made from cast aluminum, think they are Klips K 400 clones, they stick out from the back of the cabinet about 6". Think the '7s midhorn was stamped steel and was fully contained inside speaker box.
    Remembering when I built my units they called the plans something like "A Super 7." Horns would be like what came on the Klips Horn knockoff. I have about 6-7# of plasti clay covering the horn body and driver, also on the horn tweeters. You can tap the bodies with no ringing or whatever.
    Speakerlab had a big following for quite a few years, from the post hippie era when some guys had some different ideas about making their own speakers and helping other do it too(and make a few bucks too.) One of the things I took away was how alot more mass/weight /wall stiffness would help produce better sound. Alot of consideration by speaker manufactures is shipping weight, keep things as light as possible while still getting the job done. This may not always lead to the best sound. Get rid of alot of the compromises that go into making speakers and the sound gets better.
    I also built some Dynaco stuff during this period. Guess people got to the point they didn't want to build it themselves and these companies changed or went out of business. Good to see a resergence in people wanting to construct their own gear again. Think being able to share info with others on the net has been a big boost in these endeavors.
    When is the PNW event in Kelso?
  20. Doc Zinger
    612
    Seattle
    New modest addition, made an oak platform with 4 sorbane pads for each HK stack setting on sub amps, don't know if it helps or not but looks good.
    Actually this was an excuse for a post to get me off page 6 and start the decent to oblivion again.
