Mellotronix
Super Member
If this has been discussed before, please forgive me, but I have two questions.
The process that MoFi and others use for cutting masters asserts that the end result is more detail and accuracy in the final vinyl product. However, MoFi also states that, "Due to this process, there may be occasional pops or ticks, inherent in initial playback, but as the disc is played more, a high quality stylus will actually polish the groove walls and improve the sound."
I do understand something about physics and mineralogy and, yes, diamonds are harder than vinyl, so I'm not denying the obvious. But does the sound improve as the record is played more? Secondly, if so, is it true of all recordings or just half speed masters?
I suppose there is a third question which is something like at what point does the stylus start damaging the recording rather than improving it, but that's a whole other thing, so I'd be happy with your thoughts on the first two questions posed in the aforementioned. Thanks in advance.
If your answer is "uh, it depends..." I'm gonna toss a perfectly good but noisy as hell MoFi record off of my second floor balcony.
