Morinized AR XA Cartridge/Sytylus Recomendations ?
Discussion in 'Turntables' started by SonofJames, Oct 3, 2018.
  1. SonofJames
    SonofJames New Member
    30
    My AR XA gets dropped off to Marc this weekend. Looking for some ideas for Cartridge/Stylus.
    I listen to jazz, vocals, rock, electronic. I like a warm, full, 3D, presentation.
    I can get a Older Grado ZF3 pretty cheap, and thought about a Black2 or 8MZ Stylus.
    There is the Grado Prestige Black2 @ $75 new
    I have read Shure's are great trackers and are on the slightly warm, musical side.
    Open to thoughts and ideas. Thanks!
    TheHaskills likes this.
  2. Nashou66
    Nashou66 AK Subscriber Subscriber
    1,894
    West Seneca NY
    Anything sounds good I bet on a MM AR-XA !!!!!
    I had a Denon DL-110, a Sumiko Blue Point special EVO III, a Shure M75, an Adcom XC-LT and now doinf excusive duties are my Acutex M 312 carts, go between the LPM and older Bricks.
    All sound great on them but I'm an Acutex Tri-Pole fanboy and am biased towards them, But I do rememeber really liking the DL-110 on it before I added the Jewel bearings and Mass to the chassis.
    I need to revisit all those on the arm after the upgrades.
    Many like Shures and Grados on these so I'll let them chime in. never heard a Grado so I may need to get one......of the older styles .
    nashou
    TheHaskills, Straker62 and SonofJames like this.
  3. mkane
    mkane AK Subscriber Subscriber
    6,547
    103 miles N. of S.F.
    I've got a Grado w/TLZ stylus. Wonderful everywhere with our music. DSC_0473.JPG
    TheHaskills and SonofJames like this.
  4. SonofJames
    30
    Which Grado Body are you using ?
    Do you have to load the TLZ ?
  5. AvFan
    AvFan AK Subscriber Subscriber
    1,816
    El Cajon, California
    I've run a wide range of cartridges on my XB including: Shure M91ED with SAS stylus, Ortofon 2M Blue, Grado G1+ with MCZ stylus (loaded at 10k ohms), Ortofon Quintet Bronze and lastly a Shelter 501 II. The Shelter is my favorite but all the others, except possibly the 2M Blue were really nice. Marc's modified AR tonearms are capable of handling just about any cartridge based upon your current and future budget.
  6. trinhsman
    trinhsman AK Subscriber Subscriber
    1,436
    On a lake in Georgia
    1F26ECDD-17C7-4267-9A9E-BFFCB17AF14F.jpeg 4F78969A-0E6F-454F-AB01-2907E6B1B8B3.jpeg I’ve run both an Ortofon 2M Black and Grado Sonata 1 on my full Monty Marc Morin XA.
  7. boreas
    boreas "If it sounds good, it IS good." E.K.E.
    15,611
    Sonoma County, CA
    Shouldn't that be Morinated?
    TheHaskills and Barncats like this.
  8. mkane
    6,547
    TLZ's loaded @ 10k also. I think that bodies a MZ
  9. Nashou66
    1,894
    West Seneca NY
    I thought that is for Chicken? ;)
    Athanasios
  10. bobins08
    bobins08 Loving the dream Subscriber
    6,412
    St. Louis, MO
    My fully marmorinized XB has the Technics arm wand mod.
    Top 3 lately.
    Grado is a good choice. Try to find a Signature series body and then add the 8MZ or MCZ stylus.
    I am running a Stanton 681EEE on it and it is great.
    For new buys the Nagaoka MP 200 sounds great on it.
    All three have great midrange and very full bass. The Grado soundstage is quite impressive. The Nag has great detail too.
    The Denon DL 110 does not compete well with the above three on this table/arm IMO.
    I was less impressed with Shure V15-III, I like it much better on my lower mass SME arm.
    The Denon 301 mk II moving coil sounds great too but took a lot of work to dial in (no VTA adjust).
    Audiofreak71 and SonofJames like this.
  11. TheHaskills
    TheHaskills AK Subscriber Subscriber
    18
    What did you think of the Ortofon Bronze? As well the Grado G1 + MCZ stylus? Thanks!
  12. mkane
    6,547
    Anything I throw on my souped up AR sounds fantastic.
  13. AvFan
    1,816
    Both the Quintet Bronze and the G1+/MCZ are very nice. I've recently been running the Quintet on my other TT and I think it likes a little the heavier Jelco tonearm but was just fine on the XB. It did require a heavier counterweight. The Grado combo is pretty lush but it has been some time since I used it. @mkane has much more recent experience with his Grado/XA. Sounds like he likes his Grado.
    Edit: Almost forgot - Welcome to Audio Karma!
  14. TheHaskills
    18
    Thanks, I’ll be sure to post some pictures when Marc is done with the AR. Larry Spence is building the base with tiger maple and building the unit an inch taller than the stock base unit. Marc has stated that this will allow him to build weights 1/2 further below the subchassis than he does on a stock height base.
    Dirtweed likes this.
  15. AvFan
    1,816
    Well, you have the "A" team working on your AR that is for sure and please share some photos when it is finished. FYI, Larry also makes the heavier counter weight which is nice to have just in case you want to use a heavier (approximately 10gr) cartridge. When I made bases for XAs and XBs they were all 4" tall to accommodate Marc's sub chassis mass loading plus I like the look of the taller base. You didn't say, but do you have an XA or XB?
  16. TheHaskills
    18
    I have an XA. But it came with a great cue. I have another AR XA and I’m thinking about doing that one as well Marc & Larry have been very generous with their time and attention to detail. Again can’t wait to get the upgraded AR. It will replace my green UTurn turntable. Thanks for your input.
  17. captouch
    captouch AK Subscriber Subscriber
    4,645
    Bay Area, CA
  18. Audiofreak71
    Audiofreak71 Boerboelicious Subscriber
    2,364
    PNW
    I’m using a Grace F9e and a Denon DL-304 on mine I also have a Signet am10 and all sound excellent on my Morinfied XA B330CD51-1E04-4ECB-B756-7AAC783998D3.jpeg 4BD87D6F-173B-4ECA-A17E-175CB08F2181.jpeg
    Audiofreak71
    trinhsman likes this.
  19. marcmorin
    marcmorin AK Subscriber Subscriber
    9,262
    have you heard the ATN152LP stylus in the AM10 body? do you want to?
  20. Audiofreak71
    2,364
    PNW
    I haven’t heard that combo , but I’m open to trying a different stylus .
    Audiofreak71
