Most CRANKABLE Speakers
Discussion in 'Speakers' started by t j, Oct 12, 2017.
  1. t j
    t j Active Member
    252
    Can anyone suggest a mid priced speaker good for ismply cranking Metal? I have a Pioneer Sx-1250 and a Technics TT. I need some durable loudspeakers that can take some abuse. All suggestions are appreciated...
  2. bowtie427ss
    bowtie427ss arigato gozaimashita Subscriber
    16,674
    Land of Milk & Honey Boo Boo
    Cerwin Vega D-9
    If you don't mind the "pro" look, Peavey SP-2, or if you can find a pair SP-4. SP-3 is not in the same league, avoid them.
  3. CopperWizard
    CopperWizard Well-Known Member
    752
    Eugene, OR
    :rockon::idea:.
    I like to go with the Magnavox horn and 15" woofer vintage . Something about horns and metal when the mood hits.
    t j likes this.
  4. gladiator335
    gladiator335 MRTI Subscriber
    7,400
    Connecticut
    CV or Realistic Mach (I, II or III). If you want really loud and don't care about the quality at all - Infinity SM-155.
    Gnesen, Bodyblue, t j and 1 other person like this.
  5. gdmoore28
    gdmoore28 Super Member
    2,557
    Central Arkansas
    When it comes to loud and abuse, prosound speakers are the only way to go. I'd look for some EV 15 inch 2 or 3 way systems.
    m3gunner, Justgotohm and asilker like this.
  6. essNeff
    essNeff Active Member
    288
    Neverland
    Pro sound.
  7. whoaru99
    whoaru99 Epic Member
    40,951
    LoTL
    2nd.
    I'd also throw Yamaha Club series in there. They can often be had reasonably. Yamaha S215 would be similar to the SP-4.
    Here's Yamaha S215 atop JBL SR4719X.
    GD70, t j and asilker like this.
  8. the skipper
    the skipper Amateur Curmudgeon Subscriber
    2,305
    Aggieland
    If you can still find any, any DCM KX series will melt your face with a handful of watts.
    crazy-in-az and t j like this.
  9. Poinzy
    Poinzy Super Member
    1,845
    SE Michigan
    I would start looking at PA speakers if you want pure power-handling capacity, as others have already mentioned . I don't know what you mean by "mid-priced".
    t j likes this.
  10. dnpainting
    dnpainting Super Member
    2,609
    Southern CA
    3rd on the CV D-9...
    What is the room size? Reason for asking is when I had my D-9's, I could not get them far enough away from Turntable so I had to reduce the bass from flat to almost all the way down in order to crank them. My amp's sonic filter helped but could still see woofer bounce from feedback, mainly on silent or lower passes. The room size was probably 12 x 16 w/8' flat ceiling if I remember correctly.
    Not saying this will happen with you, just mentioning my experience with my conditions
    t j likes this.
  11. Hobie1dog
    Hobie1dog Super Member
    1,661
    NC
    Mid priced is a very subjective term.
  12. t j
    t j Active Member
    252
    Your suggestion?
  13. t j
    t j Active Member
    252
    Room is about 20x20, with 8' flat ceiling. Thanks!
  14. t j
    t j Active Member
    252
    I like to feel it as much as hear it. Don't mind distortion, but I tend to blow drivers.
  15. t j
    t j Active Member
    252
    Will my Pioneer SX-1250 power pa speakers adequately?
  16. Bodyblue
    Bodyblue AK Subscriber Subscriber
    2,544
    CA
    Realistic Mach 1.
    Gnesen and t j like this.
  17. fishondwan
    fishondwan AK Subscriber Subscriber
    Electro-Voice Eliminator's
    Crank em up to 11 ! :rockon:
    t j, macaltec and Roadrash like this.
  18. bryblob
    bryblob AK Subscriber Subscriber
    1,989
    Minnesota
    I would think so, a lot of pro audio speakers are efficient, but you really have to look at the efficiency or sensitivity rating. The 1250 has a good amount of power so it would drive most speakers, you just have to use common sense with the volume knob. II'll 2nd the cerwin vega d-9's, also pioneer hpm-100 or 900, RtR 280dr's will blow the house down, RtR hpr-12m, dcm kx series, and pro audio speakers with large drivers.
    t j likes this.
  19. motorstereo
    10,369
    Klipsch Chorus II's. Rated for 1000wpc and 101db sensitivity rating. You ears will give out long before they do.
    Te-Te, MarZutra, t j and 2 others like this.
  20. whoaru99
    40,951
    LoTL
    Easy enough power to get loud.
    It is not uncommon, however, for sound reinforcement speakers to be 4 ohms if you are queasy about that. But, then again, I think some of the non-pro speakers recommended are 4 ohms too.
    t j likes this.
