You don't indicate why you need the coil. How was it damaged or identified as a problem. Mark - McIntosh Service Center.Here is a picture(s) of the MR71 and the Mixer Coil L3 indicated, that is needed.
http://www.stonevintageradio.com/description.php?II=888&UID=20171124033029I have an old mr65b that is partially stripped, but these types of elements are still there. If you want to message me the mcintosh part number of what you are looking for i can check if it is on my mr65b.
We want to replace the damaged L3 with a good one.
The current L3 is damaged.
The slug is glued to the inner portion of the cardboard/wax tube which has the thread on it.
The inner layer of the cardboard /wax tube,which has the thread on it, is loose from the outer portion of the cardboard/wax tube.
The inner layer of the cardboard/wax tube turns inside of the outer layer of the cardboard/wax tube.
The slug has a crack.
We don't know the extent of the crack because we have not pulled it out, so far.
Can you help?
I think this could be a generic off the shelf item for it's vintage, meaning it could have been used in multiple models, including other than McIntosh.
That sounds like the coil may have been damaged. Regarding the slug, you may be able to loosen the slug by using some medium heat on the coil. Keep the heat cool enough to not burn the balance of the transformer. Since the Factory Parts Department may not stock a replacement one would have to have a parts unit to salvage the coil from. It should be noted that the positioning of the other wires within the Front end is critical you would need to be extremely careful not to change the position of any of the other parts within the unit.
Can you help?
