I had tried a search at the beginning of my troubleshooting and found nothing, so I am posting this in hopes of helping the next tech.
A customer's unit came to me with the following symptoms:
Very low and distorted audio output
Center of Channel Tuning (COT) meter pegged to the - side
Signal strength meter operating normally and indicating good sensitivity to the usual stations
Adjusting the bias pot (R603) would bring back the audio to some extent, but only through a VERY narrow range at the extremes.
Adjusting the COT meter pot (R610) would never put the meter in the center.
The trimpots were both defective. They are both supposed to be 500 ohms; R603 was almost 4k.
Replacement of both and re-cal brought audio and proper COT action back, but still left audio that was distorted at higher levels of modulation.
Signal tracing revealed symmetrical clipping of the final audio stages. Adjustment of Audio Level (R317) made no difference at all. Yep, yet another defective trimpot.
I ended up replacing all of the trimpots. Some were ok, but it just seemed prudent.
What a beautifully engineered tuner!
