Multiple rca DAC inputs
Discussion in 'DACs' started by rxonmymind, Jun 21, 2018.
  1. rxonmymind
    rxonmymind AK Subscriber Subscriber
    2,123
    California
    Is there a dac that will take the two rca cables from my tablet (currently streaming ) and two from the cd player for a total of four inputs and have two rca out to the aux of my vintage receiver? I've seen a couple British models but have yet to find one here in the US.
    So basically have everything run through a dac. Will I have to buy two separate dacs?
    I'll run pro audio to bypass the internal dac on the Samsung tablet.
    I'm curious on how much this will improve the sound.:)
    Thanks.
    Btw I DON'T need a headphone option as I never listen to music that way in the room.
  2. judsonw
    judsonw Well-Known Member
    846
    Bellingham, WA, USA
    Based on your description, if you have two RCA cables from your table and two from your CD player, it sounds like those cables are carrying analog signals, not digital. What outputs are you using from the tablet and cd player? I am not sure I have seen a tablet that has a coaxial digital audio out.
  3. rxonmymind
    2,123
    California
    My current set up.
    Samsung Tablet A 3.5 mm>> 2 rca/Aux in receiver
    Cd player 2 rca >> 2 rca into tape on receiver
    What I'd like to do is take both and filter them through a dac>>>Aux with a possible selector switch into the receiver and see what happens. If that's even possible.
  4. judsonw
    846
    Bellingham, WA, USA
    To run them through the DAC you will need to have a digital audio out. Using the 3.5mm out from the tablet and the 2 RCA from the CD player will not work with going into the DAC.
    For the tablet, the most probable way of getting a digital signal out is through USB (I know Apple products sometimes have an optical digital out through the headphone jack, but I do not think that Samsung has adopted this).
    For the CD player, you will need to confirm that it has a digital audio output; this would likely either be optical or coaxial. Coaxial is similar to RCA, but generally is better shielded and there are a couple other differences I do not fully remember.
    GChief and rxonmymind like this.
  5. rxonmymind
    2,123
    California
    Ok...
    But can I run a micro USB out from the tablet to a dac, then rca out from the dac to aux of the receiver. Then run audio player pro to bypass the "dac" in the tablet.
    I think.
  6. cpt_paranoia
    cpt_paranoia Super Member
    1,189
    I think you may be misunderstanding what a DAC does. A DAC doesn't take analogue signals and filter them, it converts a digital stream into analogue.
    From your description, it sounds like you want a switch.
    Alternatively, you will need digital streams from your tablet and CD player. The CD player may have an optical or coax SPDIF output, but it is very unlikely that the tablet will have anything other than USB and HDMI. You could use the USB to a USB DAC, or you could use a wireless protocol such as DLNA to stream to a streaming DAC.
  7. rxonmymind
    2,123
    California
    This! I think. Thanks I'll look into it.
  8. rxonmymind
    2,123
    California
    Unfortunately no it doesn't. Thanks for your help.
  9. cpt_paranoia
    1,189
    First, make sure your receiver doesn't have other inputs you could use, besides the aux; tape, for instance. Do you still use tape?
    Edit: just read your later post; this is what you're doing already...
  10. rxonmymind
    2,123
    California
  11. rxonmymind
    2,123
    California
    For sure tape. A Marantz 2500.
  12. Hawkeye83
    Hawkeye83 AK Subscriber Subscriber
    1,981
    East-Central Iowa
    I have two different DAC's that each do this! Peachtree Decco2 and Bel Canto 2.5. The Peachtree is an integrated amp/DAC and the Bel Canto is a DAC/preamp. Both have analog inputs as well as digital inputs. Very versatile!
    rxonmymind likes this.
  13. Bob
    Bob AK Subscriber Subscriber
    2,565
    West coast
    under 100 bux, Xiangssheng dac01 and other rebranded ones. have 5 inputs
    with each input being a stereo pair for left and right channel signals.
    CD/DVD + Aux are 2, USB, Coax, and optical make a total of 5.
    (versatile since most CDPs and DVD have optical outputs, all
    computers have USB output, other high-end players have coax,
    and the cheapy portables use RCA analogs.)
    then there's two outputs. one is SS, the other is tube. you can feed the second output
    to a dedicated headphone amp and power on, remotely, either the amp for speakers
    or the headphone amp for headphones - no hands, Ma! no button pushing.
    the DAC-01 is lower res, DAC02 models go up the resolution scales.
    I use one to control all my non phono/tuner/tape inputs, very few preamps
    allow this combination of inputs. for me I have 3 CD/DVD/SACD players, two
    DAPs, two turntables, a tuner, and a computer feed - and I don't like having a
    8x10 laminated sheet telling me what to press. nor can I use a harmony
    because most are not remote controllable.
  14. cpt_paranoia
    1,189
    That would do it; DAC plus signal switch. I guess I was being too focused on the 'DAC' bit.
    Hawkeye83 likes this.
