Mundorf MLytic AG+ 4-Pole cap users : beware of wiring, some of us got it wrong !
Discussion in 'Marantz Audio' started by Bert 1100, Aug 18, 2016.
  1. Bert 1100
    Bert 1100 Super Member
    1,176
    Planquiri, Switzerland
    Hi all,
    After reading about these 4-Pole power supply caps, I decided to give them a try.
    I was looking here and there about how to connect them, since the schematics on Mundorf's site do not include the actual markings found on the caps themselves, making it unclear.
    I found the thread by Flaxmill19 about his 140, where he drew up a wiring diagram : http://audiokarma.org/forums/index....0-stereo-power-amp-–-restoration-work.562617/
    So I wired it up like this in a Scott A457 I'm restoring for someone. It works perfectly well, but I still had doubts so I shot an email to Mundorf directly, and they replied within an hour.
    AND IT SEEMS WE GOT IT WRONG......
    Here is the exchange I had with Mundorf :
    (Note I've added the pink "WRONG" afterwards so nobody would use the pic as a guide...)
    MY MESSAGE TO MUNDORF:
    Hello,
    I am using your MLytic AG+ 4-pole capacitors in building and restoring audio amplifiers, and I wanted to be sure I understand properly the way they should be wired.
    The schematics given on your web site ( 4-Pole mlytic application note) is very clear, but I have difficulty because the markings on the capacitor ( +in +out -in -out) are not indicated on that schematic.
    So I have written in GREEN on the schematics provided on your website the equivalent markings found on the capacitors. Please let me know if I am correct with what I added on the schematics.
    If what I have written in green is wrong, please let me know and show me the proper way :)
    To sum it up :
    pin 1 = + IN
    pin 2 = - OUT
    pin 3 = + OUT
    pin 4 = - IN
    Is that correct ?
    Thank you, your help is much needed and appreciated !
    Bertrand Métrailler
    Switzerland
    THE ANSWER FROM MUNDORF :
    Dear Mr. Métrailler,
    Hoping this pinout drawing is helpful for you.
    The unmarked and set back pin is Out-.
    Transferred to the application note this means:
    1. IN+
    2. IN-
    3. OUT+
    4. OUT-
    Kind regards,
    Mirko Filke
    Head of Sales & Supply Chain
    Mundorf EB GmbH
    SO ! I got it wrong and it seems some of us as well.
    This means the minus poles need inverting, so yes it does work fine but is not optimal and as intended by the manufacturer.
    I'll be rewiring the amp I did. About its sound before and after I will not check, since It's in the middle of the restoration work.
    Hope this is useful and helps !
    KutzlerTrans and Hyperion like this.
  2. Hyperion
    49,292
    Hertfordshire, UK
    Good information, well done for chasing this down and setting the record straight. :thumbsup:
  3. whoaru99
    whoaru99 Epic Member
    40,916
    LoTL
    What is the point to conduct the return through the capacitor, re. IN- > OUT-, rather than just a single return to ground?
    I see the notes on the schematic of apparently isolating the charge current from the working current, but what does that gain?
  4. Hyperion
    49,292
    Hertfordshire, UK
    My understanding is that the current is made to flow through the actual capacitor plate or electrode, rather than a connection to the plate, this is highly advantageous apparently - not sure exactly why - eddy currents? charge distribution?
  5. Bert 1100
    1,176
    I have no idea how the 4-pole is supposed to be better than the 2-pole caps, haven't done enough reading yet, maybe even then I won't get it :biggrin:
    But I trust the manufacturers and the people on AK who have used them :)
  6. Flaxmill19
    Flaxmill19 AK Subscriber Subscriber
    166
    New Zealand
    Hi Bert,
    Very interesting response from Mundorf, my two amps with the 4 pole caps fitted with your original connections sound great, so please once you have run your amps with the Mundorf connections, please report back to the forum your thoughts on the sound.
    Tony
  7. Bert 1100
    1,176
    Definitely will, although the amp I'm putting the caps in is not my amp, and I'm not very familiar with how it sounded before the restore. But I did give it a listen beforehand.
    And I'm wondering how much difference comes from the proper direction of current flow. The most difference is likely from the construction of the cap ?
    I have a 1060 (mine this one :) ) that I started on and I want to use a 4-pole there as well, maybe a Jensen ? But I got to get it fixed first, only then onto a restore....
  8. Bert 1100
    1,176
    Update, the Scott A457 with the Mundorf 4-pole caps is now finished and running. The sound is very very nice.
    I did an A437 just before the 457 (still both here), with basically the same parts, only the main caps in the 437 are Nichicon KG (other caps are Elna Silmic II, and some films)
    The two amps are very similar in build, the 457 being more powerful.
    Before the restore, both sounded pretty much the same : bass a bit boomy, not deep, treble sharp and with no "sparkle".
    Now, they both sound very nice, the bass is better, less boomy and deeper. The midrange nice and the treble also improved a lot.
    The difference is quite noticeable between the two : the 437 in comparison sounds closed in and has less detail.
    The 457 with the 4-poles really sounds very open and airy, with very small details and low level sounds clearly audible. Very 3D. Especially nice with strings, a very snappy dynamic sound that the 437 lacks. Very life-like, mostly with acoustic instruments and "real" sounds.
    So to me it was definitely worth putting these caps in. Now, is there a difference between the two ways of connecting them ? I can't say since I only heard the "wrongly" connected caps for a few seconds to make sure it worked.
    I'm now doing my Marantz 1060, definitely will go for a 4-pole, still trying to decide Mundorf or Jensen....the price difference is quite big.
  9. Flaxmill19
    166
    New Zealand
    Hi Bert,
    Have you fitted Mundorf 4 pole capacitors to both the A457 & A437? Sounds like I will have to seriously consider changing my wiring on my two amp's 4 pole capacitors. Thanks for the feedback Bert. I will be interested to hear how your 1060 turns out as well.
    Tony
  10. Bert 1100
    1,176
    Hi Tony, no, the A437 has Nichicon KGs (the "B" ones, not Super Through).
    Only the A457 has the 4-pole Mundorfs.
  11. gvocale
    gvocale New Member
    45
    New York
    I am planning to use a 100uf Mundorf MLytic AG+ 4-Pole cap to replace a 40uf electrolytic in the HK Citation II. In the picture it is C3, the cap in the middle.
    Currently the cap grounds on the metal plate that holds it. What should I do with the two Negative poles of the 4 pole cap? Should I connect both to the same ground / plate?
    How could I separate them otherwise?
  12. Bert 1100
    1,176
    Gvocale, is C3 a power supply cap ? You need to work out with the schematics what this cap does and which wires are which so you can separate the ins and outs...
    It might not be possible....in which case yes you can connect them to the same ground.
    Maybe you can provide us with a schematic ?
  13. gvocale
    gvocale New Member
    45
    New York
    Yes, C3 is a power supply cap. Here is the schematic.
  14. Bert 1100
    1,176
    I guess here you need to have the grounds together. Most likely this will not make much difference, if any. I've been using different makes of 4-pole caps and for example with the DNM 4-pole, even though there are 2 minus posts, they require the grounds be connected together.....
    gvocale likes this.
  15. Schimmec
    Schimmec New Member
    5
    Cologne, Germany
    Hi guys, I'm thinking of using the 4-pole MLytics in the Power Supply of a Sanui au-7500. However, the original 6.800uF psu caps have an additional bypass capacitor (0,22uF) between their + and - poles. Does this mean that to recreate that configuration for each of the large caps I have to put in 2 bypass caps of half the value (0,11uF), since caps in parallel add up? Or are they technically in series (in which case I'd have to use two .44 bypass caps)? Or is the way to go a different one altogether? I'm grateful for your help!
  16. Bert 1100
    1,176
    Here the value of the bypass cap is really not very important. Bigger is better but size and price are the limits. I would use maybe 4.7uF film caps. or 1 uF. or whatever you have on hand that is close.
    4 bypass caps total needed.
    1 cap MINUS IN to PLUS IN for each big cap.
    1 cap MINUS OUT to PLUS OUT for each big cap.
    Schimmec likes this.
  17. Schimmec
    Schimmec New Member
    5
    Cologne, Germany
    Merci beaucoup, Bert! That is very helpful. I'll be sure to report back once I've undertaken this endeavour and maybe post some pics of the results [provided that I don't fail].
  18. Karl vd Berg
    Karl vd Berg Super Member
    1,969
    Hi folks,
    Sorry to ask it here, but it's for an old amp with one single filtering electrolytic cap as show below,
    I have here one Mundorf M-Lytic (6800uF/80V) 4-poles. The doubt is if I just connect the two "+" (in and out) together, and the two "-" (in and out) also together...
  19. Bert 1100
    1,176
    No, at least the pluses can be divided : from rectifier (B1) to plus in, then to amp from the plus out.
    Not sure if you can divide the minuses, since there is only one wire going to the cap.
    Karl vd Berg likes this.
  20. Karl vd Berg
    1,969
    Yes, that's my main concern.
    So the pluses can be divided: one red wire comes from rectifiers (B1) to the "in +" and, from the "out +" pole, the other red wire goes to the fuses?
