Mvp861
The new MVP861 was announced on the McIntosh website today...
:thmbsp:
VintageMac
:thmbsp:
VintageMac
ron-c said:The MVP861 is shipping now. Some dummy under forecast the sales rate so they will be in short supply for the next ninety days.
Thanks,
The Dummy
ron-c said:It would not matter as production is running over maximum planning as is. Can you say overtime?
Ron-C
ron-c said:Black level is not the same for US NT SC and that in Japan. Use the mode which looks best on your minitor? What video display do you use?
Ron-C
ron-c said:Depending on the internal scaler of the Sony TV it may look better with the 861's progressive scan turned off. Taking a 480i signal to 480p for a 720p display will not be the best solution. Most of the fixed pixel displays turn 480p, including DVI/HDMI digital 480p back into analog 480i and rescale to the display. Try the 861 both ways and do not assume progressive scan is the way to go.
thanks,
Ron-C
