MX-1000 "workout"
Discussion in 'Yamaha' started by rottalpha, Nov 26, 2017.
  1. rottalpha
    rottalpha Yamaholic Subscriber
    1,828
    Middle of Crook County
    I wanted to put a rebuilt MX-1000 through some testing, so last night I had the chance. I figured I shared the findings with the rest of the gang.
    This is no scientific test by any means and it was done on my makeshift test bench, but should give a good idea of the real life abilities of the MX.
    Ya' all know that I am already a big fan of the MX-1000 sound, so bench testing it is just for giggles.:D
    The patient: Fully restored Yamaha MX-1000
    Note: Very important to mention that ALL semis were replaced/upgraded and ALL small resistors were upgraded to metal film.
    Bench test results:
    · Idle current: ~.5A
    · Idle power consumption: ~50W
    · Full power* consumption: ~1020W
    · Clipping @ ~50v @8R or ~312W@ 8R*
    · THD @ full power, @1kHZ: 0.0004%(R), 0.0003%(L)
    Note: THD remains relatively unchanged until ~10kHZ, then it starts creeping up to ~0.004 @20kHZ
    I kept the unit @full power for over 20mins and no fire works. Dialed down to about 30v (output) and let it burn-in for another 3+ hours.
    Here are some snapshots:
    I am happy I finally got to use the dummy loads from Bhlaghsorm. I need to get them a better heatsink. It is safe to say that after about 1hr of testing I could have cooked something on those things. Last time I tried testing an MX, I realized I needed some serious dummy loads and abandoned the test. That MX was clipping at well over 50v, but the test lasted for only a few minutes before the crappy dummy loads I was using, started smoking. These bad boys get hot, but it takes them a bit to get there. Resistance staid @8R on the dot and has not drifted a bit, not even a few hours of use.
    Cheers:beerchug:
    Oilmaster and Mr. Yamaha like this.
  2. avionic
    45,470
    Fort Dodge, Iowa
    Are those arcols fastened to a heatsink ?
  3. rottalpha
    1,828
    they are Dales fastened to an old car audio amplifier heatsinks, based on what I can make of it. I badly need a proper heatsink. I am using them as I got them, but that needs to change at some point.
  4. rottalpha
    1,828
  5. Mark B
    Mark B Yamaha Fan Subscriber
    5,630
    usa
    Good stuff, thanks for sharing!
  6. rottalpha
    1,828
    One observation is that in order to deliver ~300w of power, it consumes ~1000w of energy. This tells me that it operates at near class A efficiency. ~1200W would have been typical consumption for traditional class A. I guess the sliding bias still offers some efficiencies even at full power. @30% efficiency, The MX operates as a very efficient class A or an inefficient class AB. Maybe an EE could clarify.
    Another aspect I noticed is that THD remains relatively unchanged in refference to power delivery. THD only varies with frequency...barely... as in below human ear discernible levels.
    EDIT: Math above is incorrect. I missed a "minor" variable in my calculations nd that is the amp has two channels drawing current at the same time, albeit I alternated turning the attenuator down, for each channel. So power consumption at full power needs to be retested/verrified.
  7. restorer-john
    restorer-john Addicted Member
    6,622
    Australia
    Check your THD a low power- under 1 watt and sliding up gradually to about 10 watts. That's where any problems will manifest themselves, not at full power.
  8. rottalpha
    1,828
    Thanks John!
    that's where I started...and I found none. I should have stated that the amp is at its 110% :) since it already went through a serious rehab.
    The MX amp had to vacate the bench to make room for a B-1 job, but next time I have one on the bench, I will spend more time testing at low power.
  9. rottalpha
    1,828
    I should have added...I am listening to it now at 1-2W of power and to my "perfectly damaged" hearing, it sounds very good:beerchug:
    mgkfifty likes this.
  10. amr2
    amr2 Well-Known Member
    572
    Nice tests!! Thanks for sharing. Are you testing both channels at the same time (300Wx2)? If so, the efficiency would be about 60%
    rottalpha likes this.
  11. rottalpha
    1,828
    Thanks!
    I alternated the pots individually in order not to risk messing with the wires too much, but I guess next time I will be more analytical.
  12. Beobloke
    Beobloke Super Member
    1,792
    South UK
    Where's the most important picture - namely the power meters showing full output?!! :D
  13. rottalpha
    1,828
    Lol,
    Meters will be mounted back on at some point
  14. Bert 1100
    Bert 1100 Super Member
    1,176
    Planquiri, Switzerland
    Doesn't it deliver 300 watts per channel ? then it delivers 600 watts using 1000 watts. Your efficiency just doubled :biggrin: ..
    zaibatsu, Mr. Yamaha and rottalpha like this.
  15. rottalpha
    1,828
    LOL, that is what I get for testing and doing math at night. Thanks for keeping me honest guys!
  16. rottalpha
    1,828
    good callout! I edited the post above.
  17. Mr. Yamaha
    Mr. Yamaha Not so much Yamaha lately...
    899
    Amsterdam Area, The Netherlands
    Great workout, thanks for sharing :bigok:
  18. 39cross
    39cross AK Subscriber Subscriber
    950
    Beverly, MA
    Very impressive! What are you using for testing on your bench?
  19. rottalpha
    1,828
    Audio analyzer, scope and a set of dummy loads. I also used an el cheapo watt-meter
  20. rottalpha
    1,828
    sharing some more photos from this old rebuilt
    IMG_20171030_113831418.jpg IMG_20171201_192816762.jpg 20171203_171036880_iOS.jpg 20171203_165548668_iOS.jpg
    AsRock, 2-ch, m3gunner and 2 others like this.
