macman007
Mcintosh..Made In USA
A freak thing happened 2 days ago. We had a freak lightening strike come in the window, across the room to the far wall and find it's way into my turntable while an LP was playing. I was in the bathroom, coming back to shut things down, as I knew a storm was coming. As I came up the hall and was turning into the room, it lit up so bright I was blinded and fell into the wall. The power flashed off for a heartbeat then back on again. I gathered myself as best/fast as I could and went into the room, You could smell the Ozone in the air, the MX135 and turntable were still on, but the alpha numeric display on the 135 was out, but all the other lights and indicators were still on. I shut the turntable down, then the 135, finally the HT-5100 power center that everything is plugged into to isolate it from these kinds of things. I'd never seen lightening come in a room before, let alone go across it almost 18 feet.
A short while later after the storm passed ( and I changed my shorts) I went back in to listen to more music. I powered everything up like normal it all came on as it was supposed to , the display was back on the MX-135, and everything else powered up off the power center as normal. I put a record on and started to play it, and nothing. Oh, volumes set at default zero after power down. So I turned it up. Nope, no dice... Now I'm sweating, I start checking things, is the table OK, cart wires still there, interconnects OK, Phono Stage OK, Amps OK, Speakers OK? Yep everything is gold, except there is no sound, and not only from just the Phono input, nothing on on any of the inputs, Analog or Digital types. I tried to enter SETUP, to see if I can perform a full reset. I push setup, it clicks the relay then says SETUP in the display, but no video, not composite, not component ,nor S-Video, not out of any of the video outs from either zones and all the displays are working correctly other wise. Things are getting worse, not better and now I'm I'm a sweaty mess, really getting upset, about to tears really.
So I cant exit SETUP now since I can't see a menu to know whether I can access it or not, so I try the main power switch off for 2 minute reset trick. It comes out of setup after power off for just over 2 minutes, I power it back on, the problems are still there. Eventually, I figure out the only thing I can use, or that will play normally is my Mc DVD player from its 7.1 outs to the MX-135's EXTERNAL inputs. Set the knob to External and viola, perfect sound ! Volume, bass treble loudness and the other settings all still work, but only on the external input position, good, but then again not so good. Houston, we've had a problem...
I'm pretty good working on gear, well most gear thats not all chip and processor based. The MX-135 is nothing but. Even still, I give it a shot, and spend the better part of a day tearing it down, inspecting boards and components, check voltages,diodes, the power supply, fuses ( it's never that easy for me), everything I can. I had the unit completely tore down and Inspect everything 3 times with bright light and magnification and I can find nothing amiss, not even an SMD component, nothing in any board, the face-plate boards, nothing. So I take the opportunity to clean it head to toe and make it like new again, mitigating 12 years of dirt. Put it all back together, nope still broke, so she sits and I fire off an email to Binghampton and Landon Mullen in service there, explaining everything in detail, including what I've done so far and found out, what I suspect is amiss. The reply however wasn't what I was expecting at all.
Don't get me wrong, I'm not asking for a free-bee here, not head of the line privileges, preferential treatment, but I didn't expect to be told basically were busy, were not even going going to get you on the bench until till into next year, no matter what the service secretary tells you, no matter how bad or not bad you units situation is. You can always take it to any authorized local service center....if it gets fixed,..bla bla..
Really, 6 months MINIMUM just to bench it, and you don't even know whats wrong yet, haven't laid eyes on it ? Everything still powers up and lights up, and it works 100% in the External mode. My money is on 1 of 3 things,.. #1, a chip or chips in the face-plate/operation/control electronics spiked and fried, possibly turning on the muting switched for all the inputs in the process,... #2 the Digital Audio Engine for the DSP (which controls everything including Video, BUT the EXTERNAL inputs), is fried and needs to be replaced, or #3 the programming/BIOS was scrambled from the voltage surge- power on-off rapid event, and either needs to be reloaded/updated because the software is corrupted now, or a factory reset (which I cant do) needs to be performed. Momentum Data Systems are the makers of the Digital Audio Engine but it's licensed to McIntosh, and they won't talk to me or give me any access to resources, it's their board piggy backing the McIntosh mother board, with McIntosh specific programming running it, and everything has to go thru it analog and digital, all EXCEPT the External inputs so says the schematics block diagram. It's got to be a software, DSP Engine, or chip set issue, the thing is electrically healthy, really it was isolated 6 ways to Sunday from any surges, as was everything that is connected to it, EXCEPT the air, the tonearm ground which goes to the ground on phono preamp, then the ground on the 135's case, and the tonearm and turntable motor/spindle/ arm wires. It's not a crispy critter at all no bad smells, burnt components, nothing. No other components commected are hurt or malfunctioning
I want it fixed, I don't want, and can't afford a new processor or a preamp. The new processors don't have all the inputs and outputs this one has, they lean more to, networking and streaming HDMI and theater/digital media I don't need or want any of that in my stereo/home theater, which is perfect foe me with only 7.1 channels.I have a C-32 as a back up preamp for audio, but I have to replace all its ribbon cables, the faceplate that's in rough shape, a bunch of those 10 volt caps that always fail, it's inop. at the moment.
I don't trust most shops to do the work of the 135 or any of my gear, as I've seen what they can do and it isn't pretty. 2 of the 3 authorized service shops they gave me are hacks and the third one is not proficient on the newer gear. This is why I wanted Binghanpton to do it. Terry DeWitt is on vacation till September and running 4 - 6 months back, and not sure if he does HT processors. I have no experience with Audio Classics or anyone else. I would be more than happy to do it myself, but Mcintosh wont publish/release the manual-process-equipment needed to access the units hardware and software, so that ties my hands. I don't really want to wait till next year, I mean would any of you want to be told by a company you have spent considerable money with over the years we can't do anything, not even look at it for you until next year, when next year is after New Years, 6 months away?
If any one has any ideas on how to access the hardware or any other possible fixes, or any suggestions in general, please post them. I'm not trying to get Landon in trouble, so I'm holding off on running to Ron C or Chuck H or someone up the ladder to get things moving faster. My local dealers-service centers have screwed me way too many times over the last 3 decades, and I know this isn't going to be a big deal once someone can get into the hardware and software. to check, reset, reprogram or replace the DSP engine or chips/software.
What does everyone else think?
