My Addiction.
Discussion in 'Members' Systems' started by Whitebear15, May 1, 2017.
  1. Whitebear15
    Whitebear15 AK Subscriber Subscriber
    195
    Preston Lancashire UK
    View attachment 922401 My main system, consist of JVC SX911, 1980, rocks the roof off, the big boys, Marantz 1060 amplifier with original wooden case. The JVC speakers and the Marantz 1060 is the best sound Ive ever heard. AIWA AP-2100K turntable with Shure M75-6S Cartridge. Also have ( I know its sad ) Rotel RX 504A receiver, Superscope R1270 receiver, Pioneer SX434 receiver and a pair of 1969 Wharfdale Glendale 3 speakers. 20170501_185829.jpg 20170501_190538.jpg 20170501_190455.jpg 20170501_190006.jpg ers.
    xxhanhxx, Burner, ronscat and 8 others like this.
  2. Hajidub
    Hajidub Ready for Winter! Subscriber
    4,933
    Colorado Springs, CO
    Welcome to the addiction center Whitebear, you're not alone.
    Drummond and Whitebear15 like this.
  3. mark warren
    mark warren Always Learning! Subscriber
    1,613
    southern USA
    hello and welcome! Very nice setup..............
    Whitebear15 likes this.
  4. Rome
    Rome Holsum Honey Buns Subscriber
    39,289
    Dallas, Texas
    Greetings to ya & mighty fine JVC speakers!
    Rome
  5. Dave_1962
    Dave_1962 Lunatic Member
    18,053
    Ontario, Canada
    Nice!
  6. gdmoore28
    gdmoore28 Super Member
    2,362
    Central Arkansas
    That's some pretty stuff, no doubt. No reason it shouldn't sound great.
    Wondering: do you always leave your turntable cue lever in the up position when the tonearm is clamped in its rest?
    GeeDeeEmm
  7. Whitebear15
    195
    Hi Geedee, yes I do leave the cue lever in the up position when the arm is in the clamped position, is this not a good thing to do? I could do with a new turntable, the sure cartridged is that sensative I can hear the motor in the speakers. Cheers Rob
  8. Moby Dick
    Moby Dick Active Member
    125
    The Motorcity
    That is a eye-catching setup you have.
    I'm sure it sounds great.
  9. gdmoore28
    2,362
    Central Arkansas
    Well, if your cue lever "lifter" (or whatever it's called) is working properly, it's lifting the tonearm enough that it can surmount the lip on the tonearm rest. If you are clamping your tonearm into the rest, you are doing so against the hydraulic lift mechanism. That means there is constant pressure against the hydraulics.
    Just to make sure that what I'm telling you is correct, I scanned a few turntable manuals, and all of them seem to make the assumption that when the tonearm is in the rest, the lift lever is down. I know that on both of my turntables, clamping the arm in the rest with the lift arm in the up position requires a bit of downward force against the hydraulic lift. That can't be a good thing. Eventually, something will have to give.
    If you can hear your motor thru the cartridge, something is awry. I wouldn't even know what to suggest. I just know that your motor should not be inducing noise thru your cartridge, no matter how sensitive it is. I think I'd do a post in the turntables section of this forum.
    GeeDeeEmm
  10. Whitebear15
    195
    Cheers GeeDee, I shall leave the cue lever in the down position from now on.Done some investagating and the noise I can hear is from the belt drive and mostly the dust bug. not the motor, Im on the look out for a direct drive turntable, hoping that will remove the noise..Rob
  11. gdmoore28
    2,362
    Central Arkansas
    Well, you have a very nice system with the same type of components that reside in mine most of the time. The speakers and the Marantz are just lovely, and I'll bet they sound as good as they look. Thanks for posting and sharing those with us.
    GeeDeeEmm
  12. Nightwisher
    Nightwisher Farer In The Goldilocks Zone Subscriber
    2,905
    South Carolina
    Awesome!
  13. TECH---NICS
    TECH---NICS New Member
    41
    euROpa
    i like your addiction!
  14. McBru6177
    McBru6177 Super Member
    1,426
    Toronto
    Nice gear. Choosing to collect vintage audio components is good for the soul compared to many other addictions.
    Whitebear15, Ds2000 and Nightwisher like this.
