IMTubeHead
OsteoFisheritis
Hi All,
Just wanted to post a few pics of my Extra 230(72" wingspan) that I built back around 1993. I flew it only once(I had my friend, who was a whiz kid, stand by in case I froze up or flipped out) and it had my knees shaking because this is in my opinion my very best work to date...and most expensive! I had built about 4 or 5 different planes, mostly from kits before I attempted to tackle this project. It took about 2 years on and off to finish it. I bought this kit from Tennessee Model Hobbies as a ARC(almost ready to cover), it has styrofoam core fuselage, wings, and control surfaces(rudder and elevator). I used gapless iron on hinges on all control areas to increase control effectiveness, high torque rudder(with pull/pull cable) and elevator servos, low profile high torque aileron servos(one built into each wing), and a mini servo for throttle. Engine is an OS 120 Surpass 4-Cycle(with fuel pump) using a 16 oz. fuel tank. The covering is Monokote Metallic Red, White, and Metallic Blue. The cowl and wheel pants were painted with like colors. I stained and varnished the cockpit and put "Mr. Pilot" in there! The wings are mounted onto a piece of 1/2" conduit which mounts in a fiberglass tube in the fuselage. The wing halves are secured/lined up to the fuselage with dowel pins set at the correct incidence and held in place by large thick rubber bands. Yes, the rubber bands hold very well!! The first flight was scary, as the plane was climbing throughout most of the flight. I had done my best to "pre-trim" the controls before I took it up, but it still had a climb to it. I suspect an incorrectly shimmed engine mount as the culprit. I had just gotten married around the same time I finished the plane, so you know how those things go. I still have her on my bed in the spare bedroom of my apartment. I still smile every time I look at it, and it was fun putting it together to snap these photos I'm posting. Hope you all enjoy these. I took several. I had a hell of a time trying to jockey the plane around just to snap pics because my living room is way too small. I managed, though...
John
John
