My KR-5400
Discussion in 'Kenwood-Trio/Kensonic-Accuphase' started by rickl, Jan 9, 2019.
  1. rickl
    rickl Active Member
    167
    Twin Cities
    I vowed not to pick up a receiver but found this one today cheap. Owner said it didn't work, sounded muffled, and just wanted to get rid of it.
    Got it home and plugged it to the DBT. Relay clicked in. Let it warm up and DC offset was 5mV. Plugged it in to AC, connected speakers and it works great. 3 dial lights out but FM meter and stereo indicator bulbs work.
    Not a scratch on the cover. Kind of odd. Never seen that before.
    Looking closer, I noticed it took a hit to the volume pot and bent the frame and cracked the face plate. Oh well.
    Might be perfect for the garage or I'll cut some plexiglass for face plate.
    I'm sure you know what these look like but here are a few pics.
    Got the knobs soaking in dawn, washed and waxed the aluminum.
    gort69 likes this.
  2. rickl
    rickl Active Member
    167
    Twin Cities
    Got the tone board recapped.
    I don't have fresh caps for all the electrolytics but I was able to replace a few electrolytics on the power supply and preamp board and the 1uF coupling caps with WIMAs on the preamp and power amp boards. I need to replace a pair of 3.3uF couplers into the opamp and all of the coupling caps will be fresh. I have them but it was getting late on a school night.
    What I found really nice was kenwood's board layout has multiple lead spacing for a few caps. I was able to replace a 15mm (?) with a 5mm cap.
    BTW, i sprayed all the pots and switches with contact cleaner. only the bass control needs another hit. Missed that in my first post. I didn't even try to listen to it before cleaning.
  3. rickl
    rickl Active Member
    167
    Twin Cities
    Mouser order* came in today. I typically add 3.3/50 wimas to each order. Good thing since I needed a couple. Now all couplers are fresh and only the tone amp has electrolytics.
    Got most of the remaining electrolytics replaced from my inventory. Still each need a few more for a complete re-cap but I still listened to the receiver aux for a while. Sounded great.
    *order to finish a marantz 250. cross your fingers on that one.
  4. rickl
    rickl Active Member
    167
    Twin Cities
    Amp board
  5. Blue Shadow
    21,943
    SE PA
    guessing that quad switch on the back has been cleaned? Lost a channel in that switch once. Things back there were starting to fall apart as opposed to just being dirty, IIRC.
  6. rickl
    rickl Active Member
    167
    Twin Cities
    Yep. Receiver worked but saw your post and cleaned it anyway. Always good to ask.
  7. rickl
    rickl Active Member
    167
    Twin Cities
    Got it done. New bulbs (4 dial and 1 meter bulb).
    eizner23 likes this.
  8. mikey99
    mikey99 AK Subscriber Subscriber
    438
    I have a 4400, also had problems with that Quad switch, one channel kept cutting in/out.
    Flushed it out with DeOxit, no more problems. Took awhile to figure out that was the
    problem.
  9. grillebilly
    grillebilly Empty Head Subscriber
    16,248
    Fairfax VA
    My oldest girl took one of those to college and abused it for 3 years. It almost lasted the entire stretch, one channel quit last semester.
    You look to have done justice to yours, it deserves a better fate than our old one :D
    Looks fantastic, as does your craftsmanship
    rickl likes this.
