Hey guys, Here's my latest amp. It can run with either 211 or 845 power tubes, bias is a fixed bias configuration, and I have it set up to be able to provide appropriate bias for either the 211's or 845's.
It's a SET design, I'm using Rod Coleman filament regulators, and the amp uses mosfet source followers (Toshiba 2SK3564) after the driver stage to supply grid current for the power tubes.
HV B+ is tube rectified using a pair of 6CJ3 damper diode tubes. Final HV B+ is 1050V.
The driver is made up of CCS anode loaded #27 or #56 triodes feeding a CCS anode loaded 6BL7 (driver not pictured).
I've measured output power to be in the 32W - 35W per channel range (just before clipping) with both the 211 and 845 tubes, well into A2.
Because it's got so much heft to it, I have the driver in its own chassis, I also have the raw DC supply for the filament regulators in its own chassis. So it's a 3 chassis amp, and I'm only posting pics of the power stage at this point, just because I don't have the driver and raw dc supply put together in the proper chassis'.
I'm running a few custom wound Heyboer power transformers, a few Hammond power transformers, Monolith Magnetics output transformers, and a number of Hammond chokes, as well as a few Transcendar chokes.
I don't need to run this amp full tilt with my setup, it's just nice to know that if I'm approaching swinging the grid near or just over 0, it won't crap out.
Anyways, some of you may not agree with the sand in the signal chain, but that doesn't bother me, and I find this topology really interesting, and very cool to see working in practice exactly as I had expected it to.
The guts aren't exactly pretty, but it's very solidly wired up. I have no concerns about any part of the internals.
The amp as it stands (having the driver as well as the raw DC supply which feeds the filament regulators in separate chassis') weighs in at 96 pounds. The chassis was ordered from Landfall systems.
I'm currently running with some Klipsch Forte I's, and the amp is very quiet even with these fairly efficient speakers.
Sorry, the pics aren't the greatest.
