I was having a "check Speaker" shut down of my new Yamaha. I didn't think it was the Yamaha. Checked the resistance of the speakers with the speaker wires no problem. So I pulled out my "megger" and disconnected the speaker wires from both sides. A megger checks the resistance of your installation. I found that there was a problem with the cable for the left surround. Pulled the cable out of the wall, this cable was designed for in wall installation, I found an 8" section chewed up by mice and badly corroded. The Onkyo never had a problem. The is a tribute to Yamaha Engineering it's safety systems reacted. I have a temporary 3.1 speaker setup with what speaker wire I had on hand and I have not had any problems since. Goes to show you the value of test instruments.
The meggar I have goes to 1000V, uses a 9 Volt battery for power. You can spend a lot of money on these things but for casual use the Estone I have does the job. I mostly use mine to test old coax to see if it is still usable. But it sure solved my Yamaha problem. The Estone BM500A is available from Amazon for $22 bucks.
To the moderators it would be nice to have a thread to post info about test equipment.
